MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement
Views: 5.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
108
All Time:
5,205
Comments: 5
5 comments on steps.
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
Replacing RAM or NVMe in the Stealth Pro. In order to replace the RAM or NVMe in the Stealth Pro, you'll have to remove some other parts that get in the way.
Tools
    1. MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement, Hard Drive: step 1, image 1 of 3 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement, Hard Drive: step 1, image 2 of 3 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement, Hard Drive: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • Turn off the laptop before proceeding.
      • Unscrew the 15 screws on the bottom panel using a Phillips #00 screwdriver.
      • Pry open the back cover with a plastic prying tool.
      • Unplug the battery cable from the motherboard to prevent a ground fault. Either use your hand or a pair of tweezers to unplug the battery cable.
      • Too much pressure from the spudger can break the clips that secure the back panel, but some flex is not dangerous.
      Ask FixBot
    2. MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: step 2, image 1 of 3 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: step 2, image 2 of 3 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: step 2, image 3 of 3
      • Disconnect the SATA cables from the motherboard using a plastic spudger.
      • Gently pull out the SATA cables out of the ports.
      • Grab the auburn color cable and lift up the hard drive. Slide out the hard drive while holding onto the cable.
      • Cables are fragile. Do not apply excessive force.
      Ask FixBot
    1. MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement, Battery: step 3, image 1 of 1
      • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
      • Use a Phillips screwdriver to remove the 15 screws securing the back cover.
      • Insert an opening tool or spudger in the seam and pry along the perimeter to loosen the back cover.
      • Do not insert the opening too too far into the back edge (with "Stealth" written on it), or you may damage the power LED.
      • The back cover is secured with clips. Too much pressure from the spudger can break the clips, but some flex is not dangerous.
      • Remove the back cover.
      Ask FixBot
    2. MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: step 4, image 1 of 1
      • Disconnect the battery by carefully pulling its connector towards the battery.
      • Pull parallel to the battery, not straight up.
      Ask FixBot
    3. MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: step 5, image 1 of 2 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: step 5, image 2 of 2
      • The battery is attached to the laptop with a strong adhesive.
      • Lift the battery from laptop.
      • Be careful not to bend the or puncture the battery, as that may cause a fire hazard.
      Ask FixBot
    1. MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement, RAM or NVMe: step 6, image 1 of 3 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement, RAM or NVMe: step 6, image 2 of 3 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement, RAM or NVMe: step 6, image 3 of 3
      • Once the battery is out, remove the screws at each standoff with a #00 Phillips screwdriver.
      • Remove the two additional screws under the fans.
      • Remove the screw securing the Wi-Fi card.
      • Disconnect and remove the wifi card from the motherboard.
      • Disconnect the additional cables connected to the motherboard.
      • Carefully lift the motherboard out of the computer.
      • The screen cable in the top left is short and restricts movement when removing the motherboard.
      Ask FixBot
    2. MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: step 7, image 1 of 2 MSI GS63VR 6RF Stealth Pro RAM or NVMe Replacement: step 7, image 2 of 2
      • After flipping the motherboard over, locate the RAM slots.
      • Release each stick of RAM by carefully prying the metal clips away.
      • Remove M2 screw securing NVME drive.
      • Remove or replace NVME drive.
      Ask FixBot
9 other people completed this guide.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 108
All Time: 5,205
