MSI GS60 6QE GHOST PRO 4K Battery Replacement
    1. MSI GS60 6QE GHOST PRO 4K Battery  Replacement, Battery: step 1, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Battery  Replacement, Battery: step 1, image 2 of 2
      • Remove the eleven 5mm screws with a Phillips #0 bit.
      • Remove the four 2.5mm screws with a Phillips #0 bit.
      Ask FixBot
    2. MSI GS60 6QE GHOST PRO 4K Battery  Replacement: step 2, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Battery  Replacement: step 2, image 2 of 2
      • After opening the bottom plate, locate the battery and the battery connection.
      Ask FixBot
    3. MSI GS60 6QE GHOST PRO 4K Battery  Replacement: step 3, image 1 of 2 MSI GS60 6QE GHOST PRO 4K Battery  Replacement: step 3, image 2 of 2
      • Unplug the battery connection carefully from the motherboard, and remove the old battery.
      Ask FixBot
5 other people completed this guide.
Azher Hamid
378 Reputation
2 Guides authored
USF Tampa, Team S1-G4, Nance Fall 2017 Member of USF Tampa, Team S1-G4, Nance Fall 2017
USFT-NANCE-F17S1G4
3 Members
60 Guides authored
1 Guide Comment
The screws on corners doesnt have the same length. The Guide is wrong carefull!
Hüseyin Temizkan - Reply Share
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 48
All Time: 6,198
