MSI GP62MVR 6RF Leopard Pro SSD Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
78
All Time:
1,459
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 - 4 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide demonstrates how to replace the Solid State Drive (SSD) in the MSI GP62MVR 6RF Leopard Pro laptop. It is a simple process with no special skills required. Avoid touching the circuitry when the case is open to avoid short-circuiting components or shocking yourself. If the SSD is full and storage needs to be expanded or it has been corrupted, then the SSD should be be replaced. Follow this guide to change the SSD in a MSI GP62MVR 6RF Leopard Pro. Also be sure to back up any data on the current SSD before replacing it.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. MSI GP62MVR 6RF Leopard Pro SSD Replacement, Bottom Cover: step 1, image 1 of 2 MSI GP62MVR 6RF Leopard Pro SSD Replacement, Bottom Cover: step 1, image 2 of 2
      • Place the laptop upside down.
      • Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
      Ask FixBot
    2. MSI GP62MVR 6RF Leopard Pro SSD Replacement: step 2, image 1 of 2 MSI GP62MVR 6RF Leopard Pro SSD Replacement: step 2, image 2 of 2
      • Use the Jimmy tool to evenly pry loose the bottom cover.
      • Ensure that all sides are detached from the plastic hinging before attempting to remove the bottom cover.
      Ask FixBot
    3. MSI GP62MVR 6RF Leopard Pro SSD Replacement: step 3, image 1 of 1
      • Remove the back cover.
      • Touching circuitry could damage components or result in personal shock; it is recommended that you now wear latex gloves to prevent both issues.
      Ask FixBot
    1. MSI GP62MVR 6RF Leopard Pro SSD Replacement, SSD: step 4, image 1 of 1
      • Push the tab down to release the SSD.
      • Remove the SSD.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 78
All Time: 1,459
