MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
103
All Time:
2,470
Comments: 3
3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide demonstrates how to replace the LCD screen in the MSI GP62MVR 6RF Leopard Pro laptop. It is a moderately difficult process with no special skills required. Avoid touching the circuitry when the screen is off to avoid short-circuiting components or shocking yourself. If the screen has odd pixels, discolored or incorrect textures, or fails to display anything at all, then the LCD screen will need to be replaced. Follow this guide to change the LCD screen in a MSI GP62MVR 6RF Leopard Pro.
Tools
    1. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement, LCD Screen: step 1, image 1 of 2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement, LCD Screen: step 1, image 2 of 2
      • Using the Jimmy tool, pry the front cover off at the seam.
      • The Jimmy tool is the utensil in the first picture in the user's hand.
      Ask FixBot
    2. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: step 2, image 1 of 2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: step 2, image 2 of 2
      • Remove the four 2 mm screws on the bottom and top corners of the screen using a Phillips #0 screwdriver.
      Ask FixBot
    3. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: step 3, image 1 of 1
      • Using the Jimmy, pry off the unscrewed LCD display.
      • Make sure the black adhesive is out of the way.
      • Don't pull the screen completely off, as the screen will still be attached.
      Ask FixBot
    4. MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: step 4, image 1 of 2 MSI GP62MVR 6RF Leopard Pro LCD Screen Replacement: step 4, image 2 of 2
      • Remove the ribbon cable by pulling on the bar code tab.
      Ask FixBot
3 Guide Comments
Hey Jordan, when reassembling the front cover (which in my case, a GP63 Leopard 8RE, is glued at the bottom) what type of glue should be used? Thanks
Jaime Blasco - Reply Share
Hi Jaime, two part expoxy (Alraldite) glue should work, otherwise 3M double-sided adhesive tape would work as well.
Jordan Buck - Reply Share
Hi Jordan,
If the screen is damaged due to the cover itself being bent, do you have any advice?
Thanks
Ainsley - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 103
All Time: 2,470
