Introduction
Go to step 1 ↓This guide demonstrates how to replace the fans in the MSI GP62MVR 6RF Leopard Pro laptop. It is a difficult process with no special skills required. Avoid touching the circuitry when the case is open to avoid short-circuiting components or shocking yourself. If your fans are not turning on or are turning slow, and the laptop is overheating, then the fans will need to be replaced. Follow this guide to change the fans in a MSI GP62MVR 6RF Leopard Pro.
Tools
Place the laptop upside down.
Remove the sixteen 5.5 mm screws with a Phillips #0 screwdriver.
Remove the eight 4.5 mm screws that hold the heat sink to the motherboard with a Phillips #0 screwdriver.
Remove the four 4.5 mm screws holding the fan in place also using a Phillips #0 screwdriver.
