Up to 20% off select tools
MSI GP60 2PE Leopard RAM Replacement
Views: 2K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
73
All Time:
1,991
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 6 - 8 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Is your computer running slow, or do you need more memory? Use this guide to replace the RAM in your device.
    1. MSI GP60 2PE Leopard RAM Replacement, Battery: step 1, image 1 of 1
      • Flip MSI GP60 2PE Leopard, so that the back is facing up.
      Ask FixBot
    2. MSI GP60 2PE Leopard RAM Replacement: step 2, image 1 of 1
      • Find the unlock tab located on the upper right side of the device, then slide it to the right.
      Ask FixBot
    3. MSI GP60 2PE Leopard RAM Replacement: step 3, image 1 of 3 MSI GP60 2PE Leopard RAM Replacement: step 3, image 2 of 3 MSI GP60 2PE Leopard RAM Replacement: step 3, image 3 of 3
      • Slide and hold the release tab on the left side of the battery, so that you can remove the battery.
      Ask FixBot
    4. MSI GP60 2PE Leopard RAM Replacement: step 4, image 1 of 3 MSI GP60 2PE Leopard RAM Replacement: step 4, image 2 of 3 MSI GP60 2PE Leopard RAM Replacement: step 4, image 3 of 3
      • While holding the release tab, remove the battery slowly.
      Ask FixBot
    1. MSI GP60 2PE Leopard RAM Replacement, Back Panel: step 5, image 1 of 1
      • Flip the device over so the back is facing up.
      Ask FixBot
    2. MSI GP60 2PE Leopard RAM Replacement: step 6, image 1 of 2 MSI GP60 2PE Leopard RAM Replacement: step 6, image 2 of 2
      • Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
      • There is a screw located under the battery; lift the battery up to access it.
      Ask FixBot
    3. MSI GP60 2PE Leopard RAM Replacement: step 7, image 1 of 2 MSI GP60 2PE Leopard RAM Replacement: step 7, image 2 of 2
      • Once all four screws are removed, lift the back off.
      Ask FixBot
    1. MSI GP60 2PE Leopard RAM Replacement, RAM: step 8, image 1 of 1
      • Press the tabs on the side of the RAM to remove it.
      Ask FixBot
    2. MSI GP60 2PE Leopard RAM Replacement: step 9, image 1 of 1
      • Slide the RAM out of the slot carefully.
      Ask FixBot
3 other people completed this guide.
Author
with
Zoey Calcagno
672 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 73
All Time: 1,991
