MSI GP60 2PE Leopard Fan Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
62
All Time:
2,179
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 6 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Looking to replace your fan? This guide will help you do so with only a couple steps.
Tools
    1. MSI GP60 2PE Leopard Fan Replacement, Back Panel: step 1, image 1 of 1
      • Flip the device over so the back is facing up.
      Ask FixBot
    2. MSI GP60 2PE Leopard Fan Replacement: step 2, image 1 of 2 MSI GP60 2PE Leopard Fan Replacement: step 2, image 2 of 2
      • Remove the four 5mm screws from the back of the device using a Phillips #00 screwdriver.
      • There is a screw located under the battery; lift the battery up to access it.
      Ask FixBot
    3. MSI GP60 2PE Leopard Fan Replacement: step 3, image 1 of 2 MSI GP60 2PE Leopard Fan Replacement: step 3, image 2 of 2
      • Once all four screws are removed, lift the back off.
      Ask FixBot
    1. MSI GP60 2PE Leopard Fan Replacement, Fan: step 4, image 1 of 2 MSI GP60 2PE Leopard Fan Replacement, Fan: step 4, image 2 of 2
      • Remove the three 5 mm screws from the fan with a Phillips #00 screwdriver.
      Ask FixBot
    2. MSI GP60 2PE Leopard Fan Replacement: step 5, image 1 of 3 MSI GP60 2PE Leopard Fan Replacement: step 5, image 2 of 3 MSI GP60 2PE Leopard Fan Replacement: step 5, image 3 of 3
      • Pull the wire on the bottom left of the fan out of the socket.
      • Pull the wire gently; pulling too hard could damage the wire.
      Ask FixBot
    3. MSI GP60 2PE Leopard Fan Replacement: step 6, image 1 of 2 MSI GP60 2PE Leopard Fan Replacement: step 6, image 2 of 2
      • Remove the fan.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 62
All Time: 2,179
