MSI GE72 6QF Apache Pro RAM Replacement
    1. MSI GE72 6QF Apache Pro RAM Replacement, Battery: step 1, image 1 of 2 MSI GE72 6QF Apache Pro RAM Replacement, Battery: step 1, image 2 of 2
      • Make sure the laptop is off and unplugged (not charging).
      • With the laptop closed and upside down, unscrew the nineteen 5.5mm Phillips #1 screws that keep the back cover in place.
      Ask FixBot
    2. MSI GE72 6QF Apache Pro RAM Replacement: step 2, image 1 of 1
      • Slide the optical drive out of the laptop.
      Ask FixBot
    3. MSI GE72 6QF Apache Pro RAM Replacement: step 3, image 1 of 1
      • Use a Phillips screwdriver to remove the three screws along the edge of the optical drive bay.
      Ask FixBot
    4. MSI GE72 6QF Apache Pro RAM Replacement: step 4, image 1 of 2 MSI GE72 6QF Apache Pro RAM Replacement: step 4, image 2 of 2
      • Using your fingers, gently loosen the edges of all four sides of the back cover.
      • Gently pull off the back cover.
      Ask FixBot
    5. MSI GE72 6QF Apache Pro RAM Replacement: step 5, image 1 of 2 MSI GE72 6QF Apache Pro RAM Replacement: step 5, image 2 of 2
      • Unscrew the single 5.5mm Phillips #1 screw keeping the battery secure.
      Ask FixBot
    6. MSI GE72 6QF Apache Pro RAM Replacement: step 6, image 1 of 2 MSI GE72 6QF Apache Pro RAM Replacement: step 6, image 2 of 2
      • Grab the battery with your fingers and gently pull it up and away from the rest of the laptop.
      Ask FixBot
    1. MSI GE72 6QF Apache Pro RAM Replacement, RAM: step 7, image 1 of 2 MSI GE72 6QF Apache Pro RAM Replacement, RAM: step 7, image 2 of 2
      • When you open the back cover, the RAM will be located as shown in the picture.
      Ask FixBot
    2. MSI GE72 6QF Apache Pro RAM Replacement: step 8, image 1 of 3 MSI GE72 6QF Apache Pro RAM Replacement: step 8, image 2 of 3 MSI GE72 6QF Apache Pro RAM Replacement: step 8, image 3 of 3
      • Press the hinges on the sides of the RAM chip as shown in the picture, in order to unlock it.
      • Carefully, slide it out at a 45 degree angle.
      • Don't press on the hinges too hard.
      • Be careful about the angle at which you're sliding out the chip.
      Ask FixBot
    3. MSI GE72 6QF Apache Pro RAM Replacement: step 9, image 1 of 3 MSI GE72 6QF Apache Pro RAM Replacement: step 9, image 2 of 3 MSI GE72 6QF Apache Pro RAM Replacement: step 9, image 3 of 3
      • Similarly, press on the hinges on the sides of the other RAM chip, in order to unlock it.
      • Some laptop models might not come with two RAM chips, so if that is your case, you can skip this step.
      Ask FixBot
Tanmay Kumar
461 Reputation
4 Guides authored
Cal Poly, Team S14-G4, Banghart Spring 2017 Member of Cal Poly, Team S14-G4, Banghart Spring 2017
CPSU-BANGHART-S17S14G4
4 Members
48 Guides authored
1 Guide Comment
Can you put more ram in this laptop like 32gb?
Can you put another ssd?
nojus.zibikas - Reply Share
Past 24 Hours: 3
Past 7 Days: 30
Past 30 Days: 115
All Time: 5,714
