MSI GE70 2PE Apache Pro Touchpad Replacement
    1. MSI GE70 2PE Apache Pro Touchpad Replacement, Battery: step 1, image 1 of 1
      • Turn over the laptop so the battery compartment is facing up.
      Ask FixBot
    2. MSI GE70 2PE Apache Pro Touchpad Replacement: step 2, image 1 of 1
      • Push the right latch all the way to the right until it clicks into place.
      Ask FixBot
    3. MSI GE70 2PE Apache Pro Touchpad Replacement: step 3, image 1 of 1
      • Pull and hold the left latch.
      Ask FixBot
    4. MSI GE70 2PE Apache Pro Touchpad Replacement: step 4, image 1 of 1
      • Pry the battery upward using the indent.
      Ask FixBot
    5. MSI GE70 2PE Apache Pro Touchpad Replacement: step 5, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 5, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 5, image 3 of 3
      • Continue to pull the battery until it is free of the casing.
      Ask FixBot
    1. MSI GE70 2PE Apache Pro Touchpad Replacement, Touchpad: step 6, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement, Touchpad: step 6, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement, Touchpad: step 6, image 3 of 3
      • Remove the six 5.5mm screws by using a Phillips #1 screwdriver.
      • Pry the door off using a plastic opening tool.
      Ask FixBot
    2. MSI GE70 2PE Apache Pro Touchpad Replacement: step 7, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 7, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 7, image 3 of 3
      • Remove the five 3.5mm screws by using a Phillips #1 screwdriver.
      Ask FixBot
    3. MSI GE70 2PE Apache Pro Touchpad Replacement: step 8, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 8, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 8, image 3 of 3
      • Remove the twenty-one 5.5mm screws by using a Phillips #1 screwdriver.
      Ask FixBot
    4. MSI GE70 2PE Apache Pro Touchpad Replacement: step 9, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 9, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 9, image 3 of 3
      • Disconnect the power, mic, and LVDS cables.
      Ask FixBot
    5. MSI GE70 2PE Apache Pro Touchpad Replacement: step 10, image 1 of 1
      • Turn over the laptop so the screen is open and keyboard is exposed.
      Ask FixBot
    6. MSI GE70 2PE Apache Pro Touchpad Replacement: step 11, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 11, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 11, image 3 of 3
      • Remove the two 5.5mm screws by using a Phillips #1 screwdriver.
      Ask FixBot
    7. MSI GE70 2PE Apache Pro Touchpad Replacement: step 12, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 12, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 12, image 3 of 3
      • Disconnect the touchpad, touchpad button, and power board connections.
      Ask FixBot
    8. MSI GE70 2PE Apache Pro Touchpad Replacement: step 13, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 13, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 13, image 3 of 3
      • Using the plastic opening tool, pry open the computer case.
      Ask FixBot
    9. MSI GE70 2PE Apache Pro Touchpad Replacement: step 14, image 1 of 2 MSI GE70 2PE Apache Pro Touchpad Replacement: step 14, image 2 of 2
      • Turn the panel over so that the internals are facing upward.
      Ask FixBot
    10. MSI GE70 2PE Apache Pro Touchpad Replacement: step 15, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 15, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 15, image 3 of 3
      • Remove the five 2.5mm screws by using a Phillips #1 screwdriver.
      Ask FixBot
    11. MSI GE70 2PE Apache Pro Touchpad Replacement: step 16, image 1 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 16, image 2 of 3 MSI GE70 2PE Apache Pro Touchpad Replacement: step 16, image 3 of 3
      • Using the plastic opening tool, pry the touchpad off and remove it.
      Ask FixBot
2 Guide Comments
Do you know where the replacement touchpads for MSI laptops can be purchased? The touchpad getting stuck seems to be a common issue on their forums
Connor D - Reply Share
i looking for touchpad part also…
Rafał Pawlak - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 86
All Time: 5,073
