MSI GE70 2PE Apache Pro RAM Replacement
    1. MSI GE70 2PE Apache Pro RAM Replacement, Battery: step 1, image 1 of 1
      • Turn over the laptop so the battery compartment is facing up.
      Ask FixBot
    2. MSI GE70 2PE Apache Pro RAM Replacement: step 2, image 1 of 1
      • Push the right latch all the way to the right until it clicks into place.
      Ask FixBot
    3. MSI GE70 2PE Apache Pro RAM Replacement: step 3, image 1 of 1
      • Pull and hold the left latch.
      Ask FixBot
    4. MSI GE70 2PE Apache Pro RAM Replacement: step 4, image 1 of 1
      • Pry the battery upward using the indent.
      Ask FixBot
    5. MSI GE70 2PE Apache Pro RAM Replacement: step 5, image 1 of 3 MSI GE70 2PE Apache Pro RAM Replacement: step 5, image 2 of 3 MSI GE70 2PE Apache Pro RAM Replacement: step 5, image 3 of 3
      • Continue to pull the battery until it is free of the casing.
      Ask FixBot
    1. MSI GE70 2PE Apache Pro RAM Replacement, RAM: step 6, image 1 of 3 MSI GE70 2PE Apache Pro RAM Replacement, RAM: step 6, image 2 of 3 MSI GE70 2PE Apache Pro RAM Replacement, RAM: step 6, image 3 of 3
      • Remove the six 5.5mm Phillips #1 screws.
      • Pry the door off using the plastic opening tool.
      Ask FixBot
    2. MSI GE70 2PE Apache Pro RAM Replacement: step 7, image 1 of 3 MSI GE70 2PE Apache Pro RAM Replacement: step 7, image 2 of 3 MSI GE70 2PE Apache Pro RAM Replacement: step 7, image 3 of 3
      • Gently pull the clips holding the RAM until the RAM stick pops up.
      • Slide the stick of RAM out.
      Ask FixBot
    3. MSI GE70 2PE Apache Pro RAM Replacement: step 8, image 1 of 3 MSI GE70 2PE Apache Pro RAM Replacement: step 8, image 2 of 3 MSI GE70 2PE Apache Pro RAM Replacement: step 8, image 3 of 3
      • Repeat the process for the second RAM stick.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 88
All Time: 3,461
