MSI GE70 2PE Apache Pro Keyboard Replacement
    1. MSI GE70 2PE Apache Pro Keyboard Replacement, Keyboard: step 1, image 1 of 3 MSI GE70 2PE Apache Pro Keyboard Replacement, Keyboard: step 1, image 2 of 3 MSI GE70 2PE Apache Pro Keyboard Replacement, Keyboard: step 1, image 3 of 3
      • Insert iFixit opening tool as shown in the picture to pry up on the keyboard guard.
      • Remove the keyboard guard.
      Ask FixBot
    2. MSI GE70 2PE Apache Pro Keyboard Replacement: step 2, image 1 of 3 MSI GE70 2PE Apache Pro Keyboard Replacement: step 2, image 2 of 3 MSI GE70 2PE Apache Pro Keyboard Replacement: step 2, image 3 of 3
      • Insert the iFixit tool under the plastic screw cover.
      • Grab the plastic part with your hand and lift it off the casing.
      • Remove the plastic part to reveal the screws holding the keyboard in place.
      Ask FixBot
    3. MSI GE70 2PE Apache Pro Keyboard Replacement: step 3, image 1 of 3 MSI GE70 2PE Apache Pro Keyboard Replacement: step 3, image 2 of 3 MSI GE70 2PE Apache Pro Keyboard Replacement: step 3, image 3 of 3
      • Unscrew the five screws located at the top of the keyboard.
      • Use the opening tool to lift the keyboard from its position
      • Be mindful of the ribbon cables when lifting the keyboard from the palmrest.
      Ask FixBot
2 other people completed this guide.
2 Guide Comments
What about step 4 detaching the ribbon cable?
russell89000 - Reply Share
yes missing the part of the 2 ribbon cables, one of them (the lighting) is not reachable like this..
you have to take out the battery, and then remove the back cover to reach the ribbon for the lighting
Kim Van Hoeck - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 106
All Time: 4,852
