MSI GE70 2PE Apache Pro Battery Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
71
All Time:
2,563
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide can be used to help you replace a dead or faulty battery in your MSI GE70 2PE Apache Pro. This is a straight-forward repair that requires no use of tools.
Parts
    1. MSI GE70 2PE Apache Pro Battery Replacement, Battery: step 1, image 1 of 1
      • Turn over the laptop so the battery compartment is facing up.
      Ask FixBot
    2. MSI GE70 2PE Apache Pro Battery Replacement: step 2, image 1 of 1
      • Push the right latch all the way to the right until it clicks into place.
      Ask FixBot
    3. MSI GE70 2PE Apache Pro Battery Replacement: step 3, image 1 of 1
      • Pull and hold the left latch.
      Ask FixBot
    4. MSI GE70 2PE Apache Pro Battery Replacement: step 4, image 1 of 1
      • Pry the battery upward using the indent.
      Ask FixBot
    5. MSI GE70 2PE Apache Pro Battery Replacement: step 5, image 1 of 3 MSI GE70 2PE Apache Pro Battery Replacement: step 5, image 2 of 3 MSI GE70 2PE Apache Pro Battery Replacement: step 5, image 3 of 3
      • Continue to pull the battery until it is free of the casing.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 71
All Time: 2,563
