Up to 20% off select tools
MSI GE62 7RD RAM Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
31
Past 30 Days:
101
All Time:
2,123
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
If your MSI GE62 7RD laptop isn’t up to speed for web browsing and gaming, it might be worthwhile to add more RAM (Random Access Memory). Adding more RAM is an easy way to improve a computer’s performance, especially for certain tasks like multiple tab web browsing and gaming.
However, before you add more RAM to your laptop, it might be worthwhile to make sure the slow speeds are not due to a virus, fragmented hard drive, or excessive background programs.
Before beginning, make sure to power off your laptop completely and disconnect it from any wall outlet.
    1. MSI GE62 7RD RAM Replacement, RAM: step 1, image 1 of 1
      • Flip the laptop over so that the bottom is on top.
      • Caution: make sure the laptop is fully powered off (not sleep mode) and not connected to the AC charging adapter before beginning the repair.
      Ask FixBot
    2. MSI GE62 7RD RAM Replacement: step 2, image 1 of 2 MSI GE62 7RD RAM Replacement: step 2, image 2 of 2
      • Remove the fifteen 6.5 mm Phillips #0 screws from the bottom of the laptop using a Phillips #0 screwdriver.
      • Be sure to remove the two screws in the middle of the laptop, they're easy to miss! They might be under a factory seal label.
      Ask FixBot
    3. MSI GE62 7RD RAM Replacement: step 3, image 1 of 2 MSI GE62 7RD RAM Replacement: step 3, image 2 of 2
      • Remove the back case from the laptop.
      • If the backing is really stuck, you may use a plastic opening tool or picks to provide leverage.
      Ask FixBot
    4. MSI GE62 7RD RAM Replacement: step 4, image 1 of 2 MSI GE62 7RD RAM Replacement: step 4, image 2 of 2
      • With both thumbs, pull the silver overhangs on the sides of the RAM until the old stick of RAM pops up.
      Ask FixBot
    5. MSI GE62 7RD RAM Replacement: step 5, image 1 of 1
      • Remove the old stick of RAM by pulling back and out.
      Ask FixBot
    6. MSI GE62 7RD RAM Replacement: step 6, image 1 of 2 MSI GE62 7RD RAM Replacement: step 6, image 2 of 2
      • Place the new stick of RAM in the socket so that the electrical contacts match.
      • Push the top of the stick of RAM down and in until you hear the click of the silver overhangs latch onto the RAM.
      Ask FixBot
Author
with
William Guyton
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 31
Past 30 Days: 101
All Time: 2,123
