MSI Force GC30 V2 Vibration Motor Replacement
  1. MSI Force GC30 V2 Vibration Motor Replacement, Back Cover: step 1, image 1 of 1
    • Puncture the sticker where indicated using a screwdriver, then remove the 9.1 mm-long Phillips screw.
    • Remove the six 9.2 mm-long Phillips #0 screws.
    Ask FixBot
  2. MSI Force GC30 V2 Vibration Motor Replacement: step 2, image 1 of 3 MSI Force GC30 V2 Vibration Motor Replacement: step 2, image 2 of 3 MSI Force GC30 V2 Vibration Motor Replacement: step 2, image 3 of 3
    • Insert an opening pick in the gap between the front and rear case.
    • Slide the pick around the perimeter of the controller while prying until it fully releases.
    Ask FixBot
  3. MSI Force GC30 V2 Vibration Motor Replacement, Battery: step 3, image 1 of 1
    • Use tweezers to grip the white battery connector.
    • Pull the battery connector directly out of its port.
    • Do not pull on the wires.
    Ask FixBot
  4. MSI Force GC30 V2 Vibration Motor Replacement: step 4, image 1 of 1
    • The battery is secured to the motherboard with a mild adhesive. If necessary, apply a small amount of high-concentration isopropyl alcohol beneath the battery to loosen the adhesive.
    • Pry carefully around the battery until it fully releases.
    • Take care not to puncture or bend the battery.
    • Remove the battery.
    Ask FixBot
  5. MSI Force GC30 V2 Vibration Motor Replacement, Vibration Motor: step 5, image 1 of 3 MSI Force GC30 V2 Vibration Motor Replacement, Vibration Motor: step 5, image 2 of 3 MSI Force GC30 V2 Vibration Motor Replacement, Vibration Motor: step 5, image 3 of 3
    • Use blunt tweezers to disconnect both of the vibration motor connectors from the motherboard.
    • Grip the white connectors, not the wires.
    • Carefully remove both the right and left vibration motors from their housing.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 28
All Time: 430
