MSI Force GC30 V2 D-Pad Replacement
  1. MSI Force GC30 V2 D-Pad Replacement, Back Cover: step 1, image 1 of 1
    • Puncture the sticker where indicated using a screwdriver, then remove the 9.1 mm-long Phillips screw.
    • Remove the six 9.2 mm-long Phillips #0 screws.
    Ask FixBot
  2. MSI Force GC30 V2 D-Pad Replacement: step 2, image 1 of 3 MSI Force GC30 V2 D-Pad Replacement: step 2, image 2 of 3 MSI Force GC30 V2 D-Pad Replacement: step 2, image 3 of 3
    • Insert an opening pick in the gap between the front and rear case.
    • Slide the pick around the perimeter of the controller while prying until it fully releases.
    Ask FixBot
  3. MSI Force GC30 V2 D-Pad Replacement, Vibration Motor: step 3, image 1 of 3 MSI Force GC30 V2 D-Pad Replacement, Vibration Motor: step 3, image 2 of 3 MSI Force GC30 V2 D-Pad Replacement, Vibration Motor: step 3, image 3 of 3
    • Use blunt tweezers to disconnect both of the vibration motor connectors from the motherboard.
    • Grip the white connectors, not the wires.
    • Carefully remove both the right and left vibration motors from their housing.
    Ask FixBot
  4. MSI Force GC30 V2 D-Pad Replacement, D-Pad: step 4, image 1 of 3 MSI Force GC30 V2 D-Pad Replacement, D-Pad: step 4, image 2 of 3 MSI Force GC30 V2 D-Pad Replacement, D-Pad: step 4, image 3 of 3
    • Remove the 7.1 mm-long screw with a Phillips screwdriver.
    • Remove the 7 mm-long screw with a Phillips screwdriver.
    • Carefully lift the motherboard out of its housing.
    Ask FixBot
  5. MSI Force GC30 V2 D-Pad Replacement: step 5, image 1 of 3 MSI Force GC30 V2 D-Pad Replacement: step 5, image 2 of 3 MSI Force GC30 V2 D-Pad Replacement: step 5, image 3 of 3
    • Remove the rubber button membrane from the motherboard.
    Ask FixBot
  6. MSI Force GC30 V2 D-Pad Replacement: step 6, image 1 of 3 MSI Force GC30 V2 D-Pad Replacement: step 6, image 2 of 3 MSI Force GC30 V2 D-Pad Replacement: step 6, image 3 of 3
    • Remove the D-pad from the front case.
    Ask FixBot
  7. MSI Force GC30 V2 D-Pad Replacement: step 7, image 1 of 2 MSI Force GC30 V2 D-Pad Replacement: step 7, image 2 of 2
    • Optional: Remove the D-Pad end cap from D-Pad button.
    • The included alternate D-Pad end cap can be reattached after reassembling the device.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 57
All Time: 1,074
