Introduction
Go to step 1 ↓In this guide we will be replacing the battery for the MSI FORCE GC30 V2; model number/name: MSI FORCE GC30 V2. The battery is the main source of power for the device, and there are a few symptoms of a bad battery that is in need of replacements. Symptoms include short battery life after full charge, and no power is present in the device.
Tools
Puncture the sticker where indicated using a screwdriver, then remove the 9.1 mm-long Phillips screw.
Remove the six 9.2 mm-long Phillips #0 screws.
Use tweezers to grip the white battery connector.
Pull the battery connector directly out of its port.
For optimal performance, calibrate your newly installed battery after completing this guide.
3 other people completed this guide.
