MSI Force GC30 V2 ABXY Buttons Replacement
  1. MSI Force GC30 V2 ABXY Buttons Replacement, Back Cover: step 1, image 1 of 1
    • Puncture the sticker where indicated using a screwdriver, then remove the 9.1 mm-long Phillips screw.
    • Remove the six 9.2 mm-long Phillips #0 screws.
    Ask FixBot
  2. MSI Force GC30 V2 ABXY Buttons Replacement: step 2, image 1 of 3 MSI Force GC30 V2 ABXY Buttons Replacement: step 2, image 2 of 3 MSI Force GC30 V2 ABXY Buttons Replacement: step 2, image 3 of 3
    • Insert an opening pick in the gap between the front and rear case.
    • Slide the pick around the perimeter of the controller while prying until it fully releases.
    Ask FixBot
  3. MSI Force GC30 V2 ABXY Buttons Replacement, Battery: step 3, image 1 of 1
    • Use tweezers to grip the white battery connector.
    • Pull the battery connector directly out of its port.
    • Do not pull on the wires.
    Ask FixBot
  4. MSI Force GC30 V2 ABXY Buttons Replacement: step 4, image 1 of 1
    • The battery is secured to the motherboard with a mild adhesive. If necessary, apply a small amount of high-concentration isopropyl alcohol beneath the battery to loosen the adhesive.
    • Pry carefully around the battery until it fully releases.
    • Take care not to puncture or bend the battery.
    • Remove the battery.
    Ask FixBot
  5. MSI Force GC30 V2 ABXY Buttons Replacement, Vibration Motor: step 5, image 1 of 3 MSI Force GC30 V2 ABXY Buttons Replacement, Vibration Motor: step 5, image 2 of 3 MSI Force GC30 V2 ABXY Buttons Replacement, Vibration Motor: step 5, image 3 of 3
    • Use blunt tweezers to disconnect both of the vibration motor connectors from the motherboard.
    • Grip the white connectors, not the wires.
    • Carefully remove both the right and left vibration motors from their housing.
    Ask FixBot
  6. MSI Force GC30 V2 ABXY Buttons Replacement, ABXY Buttons: step 6, image 1 of 2 MSI Force GC30 V2 ABXY Buttons Replacement, ABXY Buttons: step 6, image 2 of 2
    • Remove the 7.1 mm-long Phillips #0 screw.
    • Remove the 7 mm-long Phillips #0 screw.
    Ask FixBot
  7. MSI Force GC30 V2 ABXY Buttons Replacement: step 7, image 1 of 2 MSI Force GC30 V2 ABXY Buttons Replacement: step 7, image 2 of 2
    • Remove the left/right bumper assembly.
    Ask FixBot
  8. MSI Force GC30 V2 ABXY Buttons Replacement: step 8, image 1 of 2 MSI Force GC30 V2 ABXY Buttons Replacement: step 8, image 2 of 2
    • Carefully lift the motherboard out of its casing and remove it.
    Ask FixBot
  9. MSI Force GC30 V2 ABXY Buttons Replacement: step 9, image 1 of 2 MSI Force GC30 V2 ABXY Buttons Replacement: step 9, image 2 of 2
    • Remove the ABXY button either by pulling them out or turning the controller the other side and letting the buttons fall out.
    Ask FixBot
  10. MSI Force GC30 V2 ABXY Buttons Replacement: step 10, image 1 of 3 MSI Force GC30 V2 ABXY Buttons Replacement: step 10, image 2 of 3 MSI Force GC30 V2 ABXY Buttons Replacement: step 10, image 3 of 3
    • Remove the ABXY button membrane by carefully lifting it off the motherboard.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 49
All Time: 917
