Up to 20% off select tools
MODRETRO Chromatic Disassembly
Views: 5.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
44
Past 30 Days:
271
All Time:
5,590
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This is a step by step disassembly of the MODRETRO Chromatic. Use this guide when modifying or replacing components on Chromatic.
    1. MODRETRO Chromatic Disassembly, Battery Cover and Batteries: step 1, image 1 of 3 MODRETRO Chromatic Disassembly, Battery Cover and Batteries: step 1, image 2 of 3 MODRETRO Chromatic Disassembly, Battery Cover and Batteries: step 1, image 3 of 3
      • To remove the battery cover, push upward on the battery cover lock. The battery cover will pop open.
      • Lift the battery cover off and set aside.
      • Remove the batteries.
      • Always remove the batteries before working on your Chromatic!
      Ask FixBot
    2. MODRETRO Chromatic Disassembly, Back Shell: step 2, image 1 of 3 MODRETRO Chromatic Disassembly, Back Shell: step 2, image 2 of 3 MODRETRO Chromatic Disassembly, Back Shell: step 2, image 3 of 3
      • Remove the back shell screws (x4) using a Tri-wing Y1 Screwdriver.
      • A Tri-wing Y1.5 will also work for all screws.
      • The screws near the top are a different length than the screws near the bottom of the shell.
      • Remove the back shell by lifting away from the device.
      Ask FixBot
    3. MODRETRO Chromatic Disassembly, Menu Button: step 3, image 1 of 3 MODRETRO Chromatic Disassembly, Menu Button: step 3, image 2 of 3 MODRETRO Chromatic Disassembly, Menu Button: step 3, image 3 of 3
      • Remove the menu button by lifting it off the post. It will remove with little resistance.
      Ask FixBot
    4. MODRETRO Chromatic Disassembly, Battery Tray: step 4, image 1 of 3 MODRETRO Chromatic Disassembly, Battery Tray: step 4, image 2 of 3 MODRETRO Chromatic Disassembly, Battery Tray: step 4, image 3 of 3
      • Remove the battery tray screws (x3) using a Tri-wing Y1 Screwdriver.
      • Remove the battery tray connector.
      • It is helpful to press lightly against the PCB with your off hand while working the connector loose.
      Ask FixBot
    5. MODRETRO Chromatic Disassembly, PCB: step 5, image 1 of 3 MODRETRO Chromatic Disassembly, PCB: step 5, image 2 of 3 MODRETRO Chromatic Disassembly, PCB: step 5, image 3 of 3
      • Remove the PCB screw (x1) using a Tri-wing Y1 Screwdriver.
      • Carefully lift the LCD screen ribbon cable from the PCB.
      • Handle with care!
      • Carefully remove the PCB from the front shell.
      • Lifting at a slight angle will help clear the headphone jack on the bottom more easily. This is also important during re-assembly.
      Ask FixBot
    6. MODRETRO Chromatic Disassembly, Speaker Module: step 6, image 1 of 3 MODRETRO Chromatic Disassembly, Speaker Module: step 6, image 2 of 3 MODRETRO Chromatic Disassembly, Speaker Module: step 6, image 3 of 3
      • Remove the speaker module screw (x1) using a Tri-wing Y1 Screwdriver.
      • Carefully remove the speaker module from the front shell.
      Ask FixBot
    7. MODRETRO Chromatic Disassembly, Buttons and Membranes: step 7, image 1 of 3 MODRETRO Chromatic Disassembly, Buttons and Membranes: step 7, image 2 of 3 MODRETRO Chromatic Disassembly, Buttons and Membranes: step 7, image 3 of 3
      • Remove the rubber button membranes (x3) from their pockets.
      • Remove the buttons and the D-pad from the shell with tweezers or by hand. If you flip the shell over, they will fall out freely.
      • The buttons will come out easily once the membranes are removed.
      • When re-attaching the rubber button membranes, be sure the positive features on the membranes seat securely into the pockets on the shell.
      Ask FixBot
    8. MODRETRO Chromatic Disassembly, IR Window: step 8, image 1 of 3 MODRETRO Chromatic Disassembly, IR Window: step 8, image 2 of 3 MODRETRO Chromatic Disassembly, IR Window: step 8, image 3 of 3
      • Carefully separate the IR window by gently wedging a plastic spudger between the IR window and the front shell.
      • Re-installing the IR window:
      • Note the side with the lip is inserted towards the front shell first.
      • Press in firmly until fully seated against the shell.
      • If the IR window fits loosely, the orientation is incorrect. The fit should be snug.
      Ask FixBot
    9. MODRETRO Chromatic Disassembly, Power Switch: step 9, image 1 of 1
      • Remove the power switch by lifting away from the front shell. It will remove with little resistance.
      • When re-assembling the power switch, make sure it is inserted in the OFF position.
      Ask FixBot
    10. MODRETRO Chromatic Disassembly, Cartridge Backer: step 10, image 1 of 3 MODRETRO Chromatic Disassembly, Cartridge Backer: step 10, image 2 of 3 MODRETRO Chromatic Disassembly, Cartridge Backer: step 10, image 3 of 3
      • Remove the cartridge backer screws (x3) using a Tri-wing Y1 Screwdriver.
      Ask FixBot
    11. MODRETRO Chromatic Disassembly, Battery Cover Disassembly: step 11, image 1 of 3 MODRETRO Chromatic Disassembly, Battery Cover Disassembly: step 11, image 2 of 3 MODRETRO Chromatic Disassembly, Battery Cover Disassembly: step 11, image 3 of 3
      • Remove the screws (x2) securing the latch cover using a Tri-wing Y1 Screwdriver.
      • Remove the door plate spring by fully depressing the battery cover lock. The spring should pop out.
      • Use a spudger if the spring does not fully dislodge.
      • Once the spring is removed, the battery cover lock can be removed without resistance through the underside of the battery cover.
      Ask FixBot
Finish Line
3 other people completed this guide.
Author
with
MODRETRO
264 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 44
Past 30 Days: 271
All Time: 5,590
