Up to 20% off select tools
MJS T2702 Speaker Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
81
All Time:
652
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Tools
  • Phillips #000 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This replacement guide will show you how to replace the speaker for this device. It is a simple and easy procedure that we will show you how to do at home step by step.
    1. MJS T2702 Speaker Replacement, Speaker: step 1, image 1 of 2 MJS T2702 Speaker Replacement, Speaker: step 1, image 2 of 2
      • Separate the back of the device from the face by inserting the flat end of the nylon spudger into the corner of the device to safely pry it open.
      Ask FixBot
    2. MJS T2702 Speaker Replacement: step 2, image 1 of 2 MJS T2702 Speaker Replacement: step 2, image 2 of 2
      • Remove the 4.1 mm screws connecting the speaker to the device by using the Phillips Head J #000.
      Ask FixBot
    3. MJS T2702 Speaker Replacement: step 3, image 1 of 2 MJS T2702 Speaker Replacement: step 3, image 2 of 2
      • Remove the plastic cover from the speaker by pulling it off gently with your hands.
      Ask FixBot
    4. MJS T2702 Speaker Replacement: step 4, image 1 of 1
      Ask FixBot
Author
with
Katalina Benecke
364 Reputation
3 Guides authored
Texas Tech, Team 1-13, Bennett Fall 2016 Member of Texas Tech, Team 1-13, Bennett Fall 2016
TTU-BENNETT-F16S1G13
5 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 81
All Time: 652
