Up to 20% off select tools
MID-7006 Battery Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
16
Past 30 Days:
89
All Time:
839
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
You will be shown step by step how to disassemble the device down to where the battery is located. From here we will show you how to replace the battery and then reassemble the device.
    1. MID-7006 Battery Replacement, Battery: step 1, image 1 of 2 MID-7006 Battery Replacement, Battery: step 1, image 2 of 2
      • Use the plastic opening tool to pull the screen away from the back cover.
      Ask FixBot
    2. MID-7006 Battery Replacement: step 2, image 1 of 2 MID-7006 Battery Replacement: step 2, image 2 of 2
      • Once you have seperated the back plate and the screen from each other like so, you will then begin to lift the battery peeling it off of its sticky pads.
      Ask FixBot
    3. MID-7006 Battery Replacement: step 3, image 1 of 2 MID-7006 Battery Replacement: step 3, image 2 of 2
      • Unplug the battery at the plug indicated by the plastic opening tool. (The best way to do this is to place a finger on both sides of the plug and pull out gently) Once you have removed the old battery, plug the new battery into the same plug the old one came from.
      Ask FixBot
Author
with
Derrick Gholston
201 Reputation
2 Guides authored
Texas Tech, Team 38-1, Bennett Fall 2016 Member of Texas Tech, Team 38-1, Bennett Fall 2016
TTU-BENNETT-F16S38G1
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 89
All Time: 839
