MICROS Compact Workstation 3 (310) Hard Drive Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
9
Past 30 Days:
68
All Time:
330
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Touch Screen POS machine from ORACLE / MICROS.
By default, these 310 models use soldered eMMC storage (ours were only 50gb). this is the process i used to add an ssd
    1. MICROS Compact Workstation 3 (310) Hard Drive Replacement, Remove Base: step 1, image 1 of 3 MICROS Compact Workstation 3 (310) Hard Drive Replacement, Remove Base: step 1, image 2 of 3 MICROS Compact Workstation 3 (310) Hard Drive Replacement, Remove Base: step 1, image 3 of 3
      • flip the device over and remove the power adapter hidden in the stand by unscrewing the thumbscrew, then remove the base by unscrewing the single hex screw
      Ask FixBot
    2. MICROS Compact Workstation 3 (310) Hard Drive Replacement, Remove Rear Cover: step 2, image 1 of 3 MICROS Compact Workstation 3 (310) Hard Drive Replacement, Remove Rear Cover: step 2, image 2 of 3 MICROS Compact Workstation 3 (310) Hard Drive Replacement, Remove Rear Cover: step 2, image 3 of 3
      • remove the covers for on the left side gently and disconnect the cables from the motherboard
      • unscrew the back cover. there are 8 captured hex head screws, and two loose Phillips screws. the Philips are under where the coveres were that you removed
      • flip the back cover over to the left and disconnect the cable from the motherboard
      Ask FixBot
    3. MICROS Compact Workstation 3 (310) Hard Drive Replacement, insert ssd and screw down: step 3, image 1 of 3 MICROS Compact Workstation 3 (310) Hard Drive Replacement, insert ssd and screw down: step 3, image 2 of 3 MICROS Compact Workstation 3 (310) Hard Drive Replacement, insert ssd and screw down: step 3, image 3 of 3
      • At this point you can insert your sata m.2 drive into the connector and screw it down, if your drive is a 2230. we only had 2280's in stock, to i had to desolder the screw terminal and move it to the 2280 position. note that we found not every ssd worked for this machine. we had good luck with Samsung 860 Pros
      Ask FixBot
Joel Eagles
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 68
All Time: 330
