Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
MF 2700A usage training
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
57
All Time:
390
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Very easy
Community-Contributed Guide
    1. MF 2700A usage training, GETTING TO KNOW THE MACHINE: step 1, image 1 of 1
      • The MF 2700A strapping machine is one of the most practical automatic strapping machines on the market.
      • It offers safety, uninterrupted production, practicality, easy adjustment, and an innovative design; these are some of the highlights of the MF 2700A lacito.
      • So, come with me to learn more about the machine.
      Ask FixBot
    2. MF 2700A usage training, POWER SUPPLY: step 2, image 1 of 2 MF 2700A usage training, POWER SUPPLY: step 2, image 2 of 2
      • The first step is to connect the machine's power supply to the 3-phase 220 Volts.
      • This service must be performed exclusively by a person certified in the electrical field.
      • For this, a 3-pole industrial plug must be used. (Photo 1)
      • The 3 phase cables (White) and 1 Ground (Green), which are coiled on the outside of the machine, must be installed there!
      • To connect the cables, it is necessary to use a 1/8 Philips driver!
      • Finally, simply plug the Plug into a 3-phase outlet, already supplied with 220 Volts (Photo 2)
      • Lacito is not responsible for any accidents that may occur during the electrical connection of the machine, as this service must be performed by a person who is certified, trained, and has practical knowledge in the electrical field; therefore, this person must follow all safety standards intended for the performance of this service!
      Ask FixBot
    3. MF 2700A usage training, PNEUMATIC SUPPLY: step 3, image 1 of 3 MF 2700A usage training, PNEUMATIC SUPPLY: step 3, image 2 of 3 MF 2700A usage training, PNEUMATIC SUPPLY: step 3, image 3 of 3
      • The next step is to perform the Pneumatic Connection.
      • This service must be performed exclusively by someone with a certification in the pneumatic field.
      • It is very simple to make the Pneumatic connection; just connect the PU hose and plug it into Connection 1 of the machine's Pneumatic valve! (Photo 1)
      • The Valve is located behind the coil support, the place where the PU hoses come from for the Cylinder (Piston). (Photo 2 and 3)
      • With the Pneumatic installation done, we can now open the compressed air valve and release air to the machine.
      • Lacito is not responsible for any accidents that may occur during the pneumatic connection of the machine, as this service must be performed by a certified, trained person with practical knowledge in the pneumatic field; therefore, this person must follow all safety standards intended for the performance of this service!
      Ask FixBot
    4. MF 2700A usage training, BUTTON FUNCTIONS: step 4, image 1 of 3 MF 2700A usage training, BUTTON FUNCTIONS: step 4, image 2 of 3 MF 2700A usage training, BUTTON FUNCTIONS: step 4, image 3 of 3
      • Now let's look at the functions of the controller buttons:
      • Power button, intended to turn the machine on or off. (Photo 1)
      • Emergency stop button, intended to turn off the machine in the event of an accident. (Photo 2)
      • Reset, intended to reset the machine when it has been disconnected from power or the emergency stop button has been triggered! (Photo 3)
      • Lacito Tip: The machine offers all safety requirements against electric shock, there is no need to be afraid.
      Ask FixBot
    5. MF 2700A usage training, TURNING ON THE MACHINE: step 5, image 1 of 2 MF 2700A usage training, TURNING ON THE MACHINE: step 5, image 2 of 2
      • Now that we know the functions of the buttons, we can turn on the machine.
      • To do so, press the Green Reset Button to reset the machine! (Photo 1)
      • The next step is to turn on the machine so it will be fully operational; that is, the Conveyor Belt will begin to move. Therefore, be careful not to place your hand or parts of your body near moving parts of the MF 2700A!
      • Next, press the On Button (green) to turn on the machine. (Photo 2)
      • Since the On Button has been pressed, the conveyor belt should begin to move.
      • If the machine does not turn on, contact us at: manutencao1@lacito.com.br or by phone: (11) 94565-8120
      Ask FixBot
    6. MF 2700A usage training, Operation: step 6, image 1 of 2 MF 2700A usage training, Operation: step 6, image 2 of 2
      • So when the machine is turned on, and the inductive sensor (Photo 1) detects an object passing by it, the machine will perform the packaging sealing cycle.
      • It is important to perform this test to see if the machine is working correctly.
      • With the test done, we can turn off the machine; to do so, press the Red Button, (Photo 2)
      Ask FixBot
    7. MF 2700A usage training, EMERGENCY STOP BUTTON: step 7, image 1 of 1
      • In the event of an emergency stop, press the Emergency stop button, which will remain locked in the pressed position, immediately cutting off electrical power to the machine and stopping its operation.
      • To release the Emergency stop button, turn it clockwise.
      • Test the operation of the Emergency stop button whenever starting a work shift.
      • Never use the Emergency stop button to turn off the machine (only in case of emergency).
      • It is prohibited to remove any safety item from your machine, under penalty of voiding the warranty and potential machine malfunction.
      Ask FixBot
    8. MF 2700A usage training, INSTALLING THE COIL: step 8, image 1 of 3 MF 2700A usage training, INSTALLING THE COIL: step 8, image 2 of 3 MF 2700A usage training, INSTALLING THE COIL: step 8, image 3 of 3
      • Now we are going to install the Lacito strapping coils into the machine.
      • The first step is to remove the Coil support. (Photo 1)
      • If it is stuck, loosen the Hexagonal set screw and then remove the coil support! (Photo 1)
      • The next step is to place the Coil on the coil holder. Place the Coil in such a way that it unwinds in a Counter-clockwise direction, meaning the strap comes out toward the back of the machine! (Photo 2)
      • Then replace the Coil support on the Coil holder until the Strapping coil is tight, and then re-tighten the Hexagonal set screw (Photo 3)
      Ask FixBot
    9. MF 2700A usage training, OPENING PROCESS: step 9, image 1 of 3 MF 2700A usage training, OPENING PROCESS: step 9, image 2 of 3 MF 2700A usage training, OPENING PROCESS: step 9, image 3 of 3
      • The following step must be performed with the machine powered off.
      • The next step after placing the Coil in the machine is to Remove the front protective cover! (Photo 1)
      • To do this, remove the 2 hex screws. (Photo 2)
      • Then, remove the front protective cover. (Photo 3)
      Ask FixBot
    10. MF 2700A usage training, INSERTING THE STRAP INTO THE MACHINE: step 10, image 1 of 3 MF 2700A usage training, INSERTING THE STRAP INTO THE MACHINE: step 10, image 2 of 3 MF 2700A usage training, INSERTING THE STRAP INTO THE MACHINE: step 10, image 3 of 3
      • The next step is to insert the strap into the machine.
      • To do this, pass the strap through the left side pulley. (Photo 1)
      • After that, pass the strap between the compressed air PU hoses. (Photo 2)
      • Then, pass the strap through the center pulley. (Photo 3).
      Ask FixBot
    11. MF 2700A usage training, LOADING THE STRAPPING ON THE MACHINE: step 11, image 1 of 3 MF 2700A usage training, LOADING THE STRAPPING ON THE MACHINE: step 11, image 2 of 3 MF 2700A usage training, LOADING THE STRAPPING ON THE MACHINE: step 11, image 3 of 3
      • Next, the operator must pass the Strapping through the Alignment pulley. (Photo 1)
      • Then pass the Strapping through the Final guide located slightly inside the machine, as shown in photos 2 and 3.
      Ask FixBot
    12. MF 2700A usage training, THREADING THE STRAP INTO THE MACHINE: step 12, image 1 of 2 MF 2700A usage training, THREADING THE STRAP INTO THE MACHINE: step 12, image 2 of 2
      • The next step is to pass the Strap through the machine needle.
      • The Needle is located a little below the protection bracket! (Photo 1)
      • Then simply pass the Strap through the inside of the needle. (Photo 2)
      Ask FixBot
    13. MF 2700A usage training, LOADING THE STRAPPING ON THE MACHINE: step 13, image 1 of 3 MF 2700A usage training, LOADING THE STRAPPING ON THE MACHINE: step 13, image 2 of 3 MF 2700A usage training, LOADING THE STRAPPING ON THE MACHINE: step 13, image 3 of 3
      • After that, pull the strapping upward. (Photo 1)
      • Then, tie the strapping to the knife holder. (Photo 2)
      • Finally, check that the strapping is passing through all the pulleys and the final guide! (Photo 3)
      Ask FixBot
    14. MF 2700A usage training, FINAL ADJUSTMENTS: step 14, image 1 of 2 MF 2700A usage training, FINAL ADJUSTMENTS: step 14, image 2 of 2
      • Finally, just close the Protection Bracket! (Photo 1)
      • To close, simply place the Front Protection Cover, securing it with the Hex Screws! (Photo 2)
      Ask FixBot
    15. MF 2700A usage training, FINAL ADJUSTMENTS: step 15, image 1 of 3 MF 2700A usage training, FINAL ADJUSTMENTS: step 15, image 2 of 3 MF 2700A usage training, FINAL ADJUSTMENTS: step 15, image 3 of 3
      • The next step is to adjust the Side support platform.
      • The side support platform is intended to adjust the bread on the Conveyor belt.
      • Then, with the machine off, place a packaged bread on the conveyor belt. (Photo 1)
      • Next, loosen the 2 side platform fasteners. (Photo 2)
      • Then adjust your side support platform so that your bread is snug on the conveyor belt. (Photo 3)
      Ask FixBot
    16. MF 2700A usage training, OPERATION: step 16, image 1 of 2 MF 2700A usage training, OPERATION: step 16, image 2 of 2
      • Finally, turn on the machine and begin placing the Bread onto the Machine conveyor belt.
      • With that, every time the Inductive Sensor detects an object, the MF 2700A performs the sealing process for the Packaging. (Photo 2)
      • Lacito Tip: To achieve higher production, it is important to have one operator placing the bread on the machine and another operator removing the already sealed bread from the machine!
      Ask FixBot
    17. MF 2700A usage training, THE END (THE GRAND FINALE): step 17, image 1 of 1
      • We have reached the end, leave your comment telling us what you thought; it is important for us to always be improving.
      • See you later.
      Ask FixBot
If you have any questions, please contact our maintenance department!
Author
with
Lacito
6,169 Reputation
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 57
All Time: 390
