Up to 20% off select tools
MECHREVO Z2 Laptop RAM Replacement
Views: 15K
View statistics:
Past 24 Hours:
14
Past 7 Days:
101
Past 30 Days:
409
All Time:
14,871
Comments: 2
2 guide comments.
Go to guide comments
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
  • Device name: MECHREVO Z2
  • The purpose of this guide is to replace the RAM of your laptop.
  • If your MECHREVO Z2 Laptop gets slow in use, you may need to replace or add RAM to your Laptop.
  • Please disconnect the power supply before working.
  • RAM
    1. MECHREVO Z2 Laptop RAM Replacement, RAM: step 1, image 1 of 2 MECHREVO Z2 Laptop RAM Replacement, RAM: step 1, image 2 of 2
      • Using a Phillips screwdriver, remove eighteen 1.2mm Phillips #1 screws on the back.
      Ask FixBot
    2. MECHREVO Z2 Laptop RAM Replacement: step 2, image 1 of 2 MECHREVO Z2 Laptop RAM Replacement: step 2, image 2 of 2
      • Remove the back plane.
      • Locate the memory slot.
      Ask FixBot
    3. MECHREVO Z2 Laptop RAM Replacement: step 3, image 1 of 2 MECHREVO Z2 Laptop RAM Replacement: step 3, image 2 of 2
      • Open the retaining latches on either side of the RAM card with your fingers or plastic tool.
      • When both anchor pins are open, the RAM pops up.
      • Remove the RAM.
      Ask FixBot
    4. MECHREVO Z2 Laptop RAM Replacement: step 4, image 1 of 3 MECHREVO Z2 Laptop RAM Replacement: step 4, image 2 of 3 MECHREVO Z2 Laptop RAM Replacement: step 4, image 3 of 3
      • Align the notched part of the RAM with the raised part of the card slot.
      • Push inward until the notch and bulge coincide.
      • Press the other end of RAM down with your finger.
      • When you hear a clicking sound indicating that the retaining clips are reengaged, you are done installing.
      Ask FixBot
    5. MECHREVO Z2 Laptop RAM Replacement: step 5, image 1 of 2 MECHREVO Z2 Laptop RAM Replacement: step 5, image 2 of 2
      • Assemble the back plate.
      Ask FixBot
要放大说明您的设备,请进行这些操作。
17 other people completed this guide.
Author
with
Songxun Cai
615 Reputation
1 Guide authored
2 Guide Comments
Where can I find support for my mechrevo z2-g series gk5cp6z?
J. Sowell - Reply Share
Past 24 Hours: 14
Past 7 Days: 101
Past 30 Days: 409
All Time: 14,871
