Up to 20% off select tools
M3t Kiosk Preventative maintenance
View statistics:
Past 24 Hours:
7
Past 7 Days:
25
Past 30 Days:
100
All Time:
933
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
    1. M3t Kiosk  Preventative maintenance, Handle and Lock: step 1, image 1 of 1
      • Make sure the door lock and handle are in good working order and not bent or loose
      Ask FixBot
    2. M3t Kiosk  Preventative maintenance, Opt cords: step 2, image 1 of 2 M3t Kiosk  Preventative maintenance, Opt cords: step 2, image 2 of 2
      • Check the opt cords to make sure they aren’t broken or crimped
      Ask FixBot
    3. M3t Kiosk  Preventative maintenance, Opt Lights: step 3, image 1 of 1
      • Make sure all the opt box lights that are supposed to be on are on.
      Ask FixBot
    4. M3t Kiosk  Preventative maintenance, Dispenser Belts: step 4, image 1 of 2 M3t Kiosk  Preventative maintenance, Dispenser Belts: step 4, image 2 of 2
      • Clean belts on top and on the back of the dispenser.
      Ask FixBot
    5. M3t Kiosk  Preventative maintenance, Test Dispense: step 5, image 1 of 3 M3t Kiosk  Preventative maintenance, Test Dispense: step 5, image 2 of 3 M3t Kiosk  Preventative maintenance, Test Dispense: step 5, image 3 of 3
      • Test dispense the coin hoppers and the cash dispenser
      Ask FixBot
    6. M3t Kiosk  Preventative maintenance, Test Dispense (continued): step 6, image 1 of 2 M3t Kiosk  Preventative maintenance, Test Dispense (continued): step 6, image 2 of 2
      • (Continued)
      Ask FixBot
    7. M3t Kiosk  Preventative maintenance: step 7, image 1 of 1
      • Check the coin hoppers to make sure nothing is in it other than coins (like rubber bands or something that was dropped in it)
      Ask FixBot
    8. M3t Kiosk  Preventative maintenance, Fans: step 8, image 1 of 2 M3t Kiosk  Preventative maintenance, Fans: step 8, image 2 of 2
      • Clean any dust off of the fans
      Ask FixBot
    9. M3t Kiosk  Preventative maintenance, Printer: step 9, image 1 of 1
      • Check the printer for paper and put in more if it's needed
      Ask FixBot
    10. M3t Kiosk  Preventative maintenance: step 10, image 1 of 2 M3t Kiosk  Preventative maintenance: step 10, image 2 of 2
      • Open and blow out the printer to remove any loose paper
      Ask FixBot
    11. M3t Kiosk  Preventative maintenance, Clean Bill Validator: step 11, image 1 of 1
      • Run a cleaning strip through the BV
      Ask FixBot
    12. M3t Kiosk  Preventative maintenance, Bill Validator board: step 12, image 1 of 1
      • Check for coins on the BV board.
      Ask FixBot
    13. M3t Kiosk  Preventative maintenance, Bill Validator protector: step 13, image 1 of 1
      • Put a board protector on if it’s missing and you have one available
      Ask FixBot
    14. M3t Kiosk  Preventative maintenance, Screen cleaning: step 14, image 1 of 1
      • Clean the touch screen
      Ask FixBot
    15. M3t Kiosk  Preventative maintenance, Door lights: step 15, image 1 of 1
      • Check to see if the door lights are on and working
      Ask FixBot
2 other people completed this guide.
Author
with
Timothy Morse
1,198 Reputation
6 Guides authored
The Curo Group Member of The Curo Group
Community
2 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 100
All Time: 933
