Up to 20% off select tools
M3D Micro Motor Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
95
All Time:
2,431
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
When printing, your extruder may not work properly, the reason of this may be related to one of the two motors. If you determined that one of the motors could be the ones causing trouble, you will need to replace it. Through this guide we intend to show the step by step process that one must take to safely remove and replace the motor of a M3D Micro.
    1. M3D Micro Motor Replacement, M3D Micro Frame Removal: step 1, image 1 of 1
      • Removing the frame is necessary to access the z axis belt, motors and ports. Make sure the unit is unplugged and set on a hard level surface.
      Ask FixBot
    2. M3D Micro Motor Replacement: step 2, image 1 of 3 M3D Micro Motor Replacement: step 2, image 2 of 3 M3D Micro Motor Replacement: step 2, image 3 of 3
      • Pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks. Lift the extruder assembly out of the way.
      Ask FixBot
    3. M3D Micro Motor Replacement: step 3, image 1 of 2 M3D Micro Motor Replacement: step 3, image 2 of 2
      • No tools are required to remove the frame. Press down on the printing bed with your thumbs while lifting the frame with your fingers. The frame easily slides up.
      Ask FixBot
    1. M3D Micro Motor Replacement, Motor: step 4, image 1 of 1
      • Once the base is opened you should find a circuit board and two motors like the one on the right, select the motor to be replaced.
      Ask FixBot
    2. M3D Micro Motor Replacement: step 5, image 1 of 2 M3D Micro Motor Replacement: step 5, image 2 of 2
      • Unplug the connectors for the Orange, Blue, Gray and Black cables. These would be the motor cables.
      Ask FixBot
    3. M3D Micro Motor Replacement: step 6, image 1 of 2 M3D Micro Motor Replacement: step 6, image 2 of 2
      • Once disconnected you will proceed to lift the motor using pliers.
      Ask FixBot
    4. M3D Micro Motor Replacement: step 7, image 1 of 2 M3D Micro Motor Replacement: step 7, image 2 of 2
      • Now, remove the motor.
      Ask FixBot
Author
with
Miguel Pina
122 Reputation
1 Guide authored
USF Tampa, Team S3-G2, Nance Fall 2017 Member of USF Tampa, Team S3-G2, Nance Fall 2017
USFT-NANCE-F17S3G2
4 Members
72 Guides authored
1 Guide Comment
Hello, good work and explanation. Is there any possibility to replace MICRO+ X-AXIS MOTOR “gear” please. Thanks
robozeka - Reply Share
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 95
All Time: 2,431
