Up to 20% off select tools
M3D Micro Frame Removal
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
94
All Time:
2,042
Comments: 2
2 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide serves as a prerequisite guide for replacing the z axis motor, the motors and ports. It shows how to remove the frame so these parts can be replaced.
    1. M3D Micro Frame Removal, M3D Micro Frame Removal: step 1, image 1 of 1
      • Removing the frame is necessary to access the z axis belt, motors and ports. Make sure the unit is unplugged and set on a hard level surface.
      Ask FixBot
    2. M3D Micro Frame Removal: step 2, image 1 of 3 M3D Micro Frame Removal: step 2, image 2 of 3 M3D Micro Frame Removal: step 2, image 3 of 3
      • Pull the x-rods away from the plastic sliders on the y-rods, and flip the slider upwards to release the tracks. Lift the extruder assembly out of the way.
      Ask FixBot
    3. M3D Micro Frame Removal: step 3, image 1 of 2 M3D Micro Frame Removal: step 3, image 2 of 2
      • No tools are required to remove the frame. Press down on the printing bed with your thumbs while lifting the frame with your fingers. The frame easily slides up.
      Ask FixBot
2 other people completed this guide.
Author
with
Danyel Browning
261 Reputation
2 Guides authored
USF Tampa, Team S3-G2, Nance Fall 2017 Member of USF Tampa, Team S3-G2, Nance Fall 2017
USFT-NANCE-F17S3G2
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 94
All Time: 2,042
