Up to 20% off select tools
Lower Case Recall/Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
21
Past 30 Days:
97
All Time:
3,207
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 9
9 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
I thought I was going to have to pay $150 to replace my MacBook's bottom cover. Then I found this link on the apple community pages. Hope this helps
    1. Lower Case Recall/Replacement, Lower Case Recall/Replacement: step 1, image 1 of 1
      • Apple has determined that under certain circumstances the rubber surface on some MacBooks may separate from the bottom case of the system. MacBooks shipped between October 2009 and April 2011 may experience this issue. Apple will replace the bottom case of any affected MacBook, free of charge, that exhibits the issue.
      • Bottom Case Replacement Process You may choose from three options to get a replacement bottom case for your MacBook. In all cases, your MacBook serial number will be checked to verify that it is eligible for this program.
      Ask FixBot
    2. Lower Case Recall/Replacement: step 2, image 1 of 1
      • Visit an Apple Retail Store - Set up an appointment with a Genius.
      • Visit an Apple Authorized Service Provider
      • Order a replacement bottom case kit online. Receive a kit that includes a new bottom case, screws, a Phillips head screwdriver, and instructions for how to remove the current bottom case and install the new one. If you feel comfortable with the self-service option, you can place your order via the web. https://supportform.apple.com/201105/
      Ask FixBot
    3. Lower Case Recall/Replacement: step 3, image 1 of 1
      • Additional Information If you believe you have paid for a repair or replacement due to this issue, contact Apple regarding a refund.
      Ask FixBot
    4. Lower Case Recall/Replacement: step 4, image 1 of 1
      • This worldwide Apple program does not extend the standard warranty coverage of the affected MacBook. This program covers affected MacBooks for FOUR years from original purchase date. Apple will continue to evaluate the service data and will provide further extensions to this program as needed.
      Ask FixBot
I accidentally came across this. Thought I would share, in case others were having the same problem.
3 other people completed this guide.
Author
with
Gamzee Makara
266 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 97
All Time: 3,207
