Up to 20% off select tools
Low Beam Bulb Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
17
Past 7 Days:
101
Past 30 Days:
353
All Time:
2,165
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. Low Beam Bulb Replacement, Low Beam Bulb: step 1, image 1 of 1
      • Gather appropriate tools such as gloves for protection and a screwdriver. Ensure that your car’s headlights are off.
      Ask FixBot
    2. Low Beam Bulb Replacement: step 2, image 1 of 1
      • Locate the lever to open the hood. This lever should be to the left on the driver’s side. Pull up the lever to pop open the hood.
      Ask FixBot
    3. Low Beam Bulb Replacement: step 3, image 1 of 1
      • This is what the view should look like once the hood is opened all the way.
      Ask FixBot
    4. Low Beam Bulb Replacement: step 4, image 1 of 1
      • Locate the cover for the headlight (black, circular) that needs to be removed.
      Ask FixBot
    5. Low Beam Bulb Replacement: step 5, image 1 of 1
      • Rotate the cover counter clockwise to remove it.
      Ask FixBot
    6. Low Beam Bulb Replacement: step 6, image 1 of 1
      • Locate the light on the inside of the headlight once the cover is removed.It should look like this.
      Ask FixBot
    7. Low Beam Bulb Replacement: step 7, image 1 of 1
      • Nudge the light (socket and bulb) with the help of a screwdriver to pull it out. Use gloves and be careful not to touch the bulb.
      Ask FixBot
    8. Low Beam Bulb Replacement: step 8, image 1 of 1
      • This is what the socket should looks like once it is pulled out.The bulb is plugged into the socket.
      Ask FixBot
    9. Low Beam Bulb Replacement: step 9, image 1 of 1
      • Unplug the bulb from the socket. The bulb should look like this
      Ask FixBot
    10. Low Beam Bulb Replacement: step 10, image 1 of 1
      • Look up what bulb is appropriate for your make, model and year.You can do so by going to your auto parts store and ask an associate to provide the information. You can also check online.
      Ask FixBot
    11. Low Beam Bulb Replacement: step 11, image 1 of 1
      • Plug the new bulb, into the socket.
      Ask FixBot
    12. Low Beam Bulb Replacement: step 12, image 1 of 1
      • Insert the socket with the bulb into this hole, and the twist clock wise to secure the bulb.
      Ask FixBot
    13. Low Beam Bulb Replacement: step 13, image 1 of 1
      • Go to the light switch and turn on the low beams.
      Ask FixBot
    14. Low Beam Bulb Replacement: step 14, image 1 of 1
      • Go to the front of the car to check to make sure the bulb is working.
      Ask FixBot
    15. Low Beam Bulb Replacement: step 15, image 1 of 1
      • Now that you know the bulb works you can screw the protective lid (screw counter clock wise) back on and close the hood of your car
      Ask FixBot
Author
with
Carla Meier
241 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 17
Past 7 Days: 101
Past 30 Days: 353
All Time: 2,165
