Lovaky PC230A Battery Replacement
    1. Lovaky PC230A Battery Replacement, Battery: step 1, image 1 of 2 Lovaky PC230A Battery Replacement, Battery: step 1, image 2 of 2
      • Turn off the keyboard by sliding the power switch to the off position. The switch is located on the top right of the front of the keyboard.
      • Make sure that the keyboard is powered off before beginning to do any work on it. Working on the device with the power on can possibly lead to electric shock.
      Ask FixBot
    2. Lovaky PC230A Battery Replacement: step 2, image 1 of 2 Lovaky PC230A Battery Replacement: step 2, image 2 of 2
      • Turn over the keyboard and remove the cover to the battery compartment by lifting the tab of the battery cover up and off.
      • You can use your fingernail to do this or a wedging tool to help remove the battery cover.
      • Take the faulty battery out of the battery compartment by pushing the battery towards the spring and lifting the other end of the battery out of the compartment.
      • When inserting the new battery make sure the flat side goes against the spring and the studded side goes against the flat side.
      Ask FixBot
Sadie Bickford
135 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 25
All Time: 522
