Lorex LW2742 Night Vision IR LEDs Replacement
  1. Lorex LW2742 Night Vision IR LEDs Replacement, Night Vision IR LEDs: step 1, image 1 of 2 Lorex LW2742 Night Vision IR LEDs Replacement, Night Vision IR LEDs: step 1, image 2 of 2
    • Remove the six 10mm Torx T10 screws on the camera face.
    Ask FixBot
  2. Lorex LW2742 Night Vision IR LEDs Replacement: step 2, image 1 of 1
    • Remove the exterior lens cover.
    Ask FixBot
  3. Lorex LW2742 Night Vision IR LEDs Replacement: step 3, image 1 of 3 Lorex LW2742 Night Vision IR LEDs Replacement: step 3, image 2 of 3 Lorex LW2742 Night Vision IR LEDs Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the LED foam ring with tweezers.
    • Be aware, the electronic components of the LED board may be compromised if you use your fingers instead of tweezers for this step.
    Ask FixBot
  4. Lorex LW2742 Night Vision IR LEDs Replacement: step 4, image 1 of 2 Lorex LW2742 Night Vision IR LEDs Replacement: step 4, image 2 of 2
    • Remove the two 5mm Phillips #1 screws.
    • Remove the two 8mm Phillips #0 screws.
    • When reassembling, tighten the top and bottom 5mm screws first, followed by the left and right 8mm screws.
    Ask FixBot
  5. Lorex LW2742 Night Vision IR LEDs Replacement: step 5, image 1 of 2 Lorex LW2742 Night Vision IR LEDs Replacement: step 5, image 2 of 2
    • Use tweezers to unclip the cables to the LED board
    Ask FixBot
craig crisci
223 Reputation
1 Guide authored
USF Tampa, Team 16-1, Eyestone Fall 2016 Member of USF Tampa, Team 16-1, Eyestone Fall 2016
USFT-EYESTONE-F16S16G1
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 29
All Time: 1,474
