Lorex LW2742 Microphone Replacement
  1. Lorex LW2742 Microphone Replacement, Microphone: step 1, image 1 of 2 Lorex LW2742 Microphone Replacement, Microphone: step 1, image 2 of 2
    • Remove the six 10mm Torx T10 screws on camera face.
    Ask FixBot
  2. Lorex LW2742 Microphone Replacement: step 2, image 1 of 1
    • Remove the exterior lens cover.
    Ask FixBot
  3. Lorex LW2742 Microphone Replacement: step 3, image 1 of 3 Lorex LW2742 Microphone Replacement: step 3, image 2 of 3 Lorex LW2742 Microphone Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the LED foam ring with tweezers.
    • Be aware, the electronic components of the LED board may be compromised if you use your fingers instead of tweezers for this step.
    Ask FixBot
  4. Lorex LW2742 Microphone Replacement: step 4, image 1 of 1
    • Remove the two 5mm Phillips #1 screws.
    • Remove the two 8mm Phillips #0 screws.
    • When reassembling, tighten the left and right 8mm screws first. Followed by the top and bottom 5mm screws.
    Ask FixBot
  5. Lorex LW2742 Microphone Replacement: step 5, image 1 of 1
    Ask FixBot
  6. Lorex LW2742 Microphone Replacement: step 6, image 1 of 3 Lorex LW2742 Microphone Replacement: step 6, image 2 of 3 Lorex LW2742 Microphone Replacement: step 6, image 3 of 3
    • Use tweezers to disconnect the microphone wires from the internal components of camera.
    Ask FixBot
  7. Lorex LW2742 Microphone Replacement: step 7, image 1 of 3 Lorex LW2742 Microphone Replacement: step 7, image 2 of 3 Lorex LW2742 Microphone Replacement: step 7, image 3 of 3
    • Remove the 4mm Flathead #4 screw on the bottom of the camera.
    • Remove the weatherproof gasket around the microphone with tweezers.
    Ask FixBot
  8. Lorex LW2742 Microphone Replacement: step 8, image 1 of 3 Lorex LW2742 Microphone Replacement: step 8, image 2 of 3 Lorex LW2742 Microphone Replacement: step 8, image 3 of 3
    • Remove the microphone.
    • Push the microphone from the inside out for easier removal.
    Ask FixBot
Alex Kusmierz
601 Reputation
5 Guides authored
USF Tampa, Team 16-1, Eyestone Fall 2016 Member of USF Tampa, Team 16-1, Eyestone Fall 2016
USFT-EYESTONE-F16S16G1
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 27
All Time: 574
