Lorex LHV210800 Upper Case Replacement
  1. Lorex LHV210800 Upper Case Replacement, Upper Case: step 1, image 1 of 3 Lorex LHV210800 Upper Case Replacement, Upper Case: step 1, image 2 of 3 Lorex LHV210800 Upper Case Replacement, Upper Case: step 1, image 3 of 3
    • Before beginning, disconnect the DVR from power and unplug all peripheries.
    • Remove each of the two 1 cm screws on the right and left sides of the DVR with a Phillips screwdriver.
    Ask FixBot
  2. Lorex LHV210800 Upper Case Replacement: step 2, image 1 of 2 Lorex LHV210800 Upper Case Replacement: step 2, image 2 of 2
    • Remove the four 1 cm Phillips screws on the rear panel.
    • Do not unscrew the screw connected to the lower case.
    Ask FixBot
  3. Lorex LHV210800 Upper Case Replacement: step 3, image 1 of 1
    • Lift up and remove the top cover.
    Ask FixBot
Maxwell Cash
387 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 18
All Time: 197
