Lorex LHV210800 Fan Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
61
All Time:
557
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
If your DVR is running louder than usual or overheating, a worn-out fan could be the main issue. This guide will walk you through the process of safely replacing the fan to not cause any long term damage to the rest of your device. Whether you're looking for an easier way to save money on replacements or like doing DIY projects, this step-by-step guide will help you complete the task with tools that you may have at home and technical experience.
Tools
    1. Lorex LHV210800 Fan Replacement, Upper Case: step 1, image 1 of 3 Lorex LHV210800 Fan Replacement, Upper Case: step 1, image 2 of 3 Lorex LHV210800 Fan Replacement, Upper Case: step 1, image 3 of 3
      • Before beginning, disconnect the DVR from power and unplug all peripheries.
      • Remove each of the two 1 cm screws on the right and left sides of the DVR with a Phillips screwdriver.
      Ask FixBot
    2. Lorex LHV210800 Fan Replacement: step 2, image 1 of 2 Lorex LHV210800 Fan Replacement: step 2, image 2 of 2
      • Remove the four 1 cm Phillips screws on the rear panel.
      • Do not unscrew the screw connected to the lower case.
      Ask FixBot
    3. Lorex LHV210800 Fan Replacement: step 3, image 1 of 1
      • Lift up and remove the top cover.
      Ask FixBot
    1. Lorex LHV210800 Fan Replacement, Fan: step 4, image 1 of 2 Lorex LHV210800 Fan Replacement, Fan: step 4, image 2 of 2
      • Unplug the red and white power cord from the socket.
      • Unplug the back panel power source.
      Ask FixBot
    2. Lorex LHV210800 Fan Replacement: step 5, image 1 of 2 Lorex LHV210800 Fan Replacement: step 5, image 2 of 2
      • Remove two of the 1 cm screws.
      • Remove the back panel where the fan is located.
      Ask FixBot
    3. Lorex LHV210800 Fan Replacement: step 6, image 1 of 2 Lorex LHV210800 Fan Replacement: step 6, image 2 of 2
      • Turn the panel around, and locate these two black studs connecting the fan and the panel together.
      • Once you are able to get those loose using the pliers, the fan should pop out, making it easier to switch out the fan and check it for issues.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Jazlyn
197 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 61
All Time: 557
