Up to 20% off select tools
Logitech Zone Wireless 2 Battery Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
35
Past 30 Days:
185
All Time:
1,582
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 30 minutes
Difficulty: Moderate
OEM Guide
iFixit collaborated with the manufacturer to make this guide.
Logitech
Logitech and iFixit are working together to help people repair their Logitech devices.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to replace a worn-out or dead battery in your Logitech Zone Wireless 2 headset.
It’s natural for batteries to lose capacity as they age. If your headset dies quickly and doesn't hold a charge, it may be time to replace the battery.
For safety, perform this repair when your battery is below 15% charge. Any charged lithium-ion battery can be hazardous if punctured or damaged. If your battery looks puffy or swollen, take appropriate precautions.
    1. Logitech Zone Wireless 2 Battery Replacement, Power off the headset: step 1, image 1 of 1
      • Power off the headset and unplug all cables.
      Ask FixBot
    2. Logitech Zone Wireless 2 Battery Replacement, Remove the ear pad: step 2, image 1 of 3 Logitech Zone Wireless 2 Battery Replacement, Remove the ear pad: step 2, image 2 of 3 Logitech Zone Wireless 2 Battery Replacement, Remove the ear pad: step 2, image 3 of 3
      • If you're replacing the battery, you only need to remove the ear pad from the side that doesn't have the boom mic.
      • With one hand, firmly hold the ear cup steady.
      • With your free hand, twist the ear pad counter-clockwise until it feels loose.
      • Remove the ear pad.
      Ask FixBot
    3. Logitech Zone Wireless 2 Battery Replacement, Reassembly note: step 3, image 1 of 3 Logitech Zone Wireless 2 Battery Replacement, Reassembly note: step 3, image 2 of 3 Logitech Zone Wireless 2 Battery Replacement, Reassembly note: step 3, image 3 of 3
      • To install the ear pad:
      • Align the ear pad's notches to the tabs on the ear cup.
      • Press the pad onto the cup.
      • Twist the pad clockwise until it locks in place.
      Ask FixBot
    1. Logitech Zone Wireless 2 Battery Replacement, Remove the speaker housing screws: step 4, image 1 of 1
      • Use a T5 Torx driver to remove the four 6.1 mm‑long screws securing the speaker housing.
      • Be careful not to drop the screws into the speaker grille. You can cover the grille with some tape to prevent accidental drops.
      Ask FixBot
    2. Logitech Zone Wireless 2 Battery Replacement, Move the speaker housing: step 5, image 1 of 3 Logitech Zone Wireless 2 Battery Replacement, Move the speaker housing: step 5, image 2 of 3 Logitech Zone Wireless 2 Battery Replacement, Move the speaker housing: step 5, image 3 of 3
      • Don't try to fully remove the speaker housing, as delicate cables connect it to the ear cup.
      • Use your fingers to lift and swing the speaker housing out of the ear cup.
      • Lean the speaker housing against a stable object, making sure not to strain the cables.
      Ask FixBot
    3. Logitech Zone Wireless 2 Battery Replacement, Disconnect the battery: step 6, image 1 of 2 Logitech Zone Wireless 2 Battery Replacement, Disconnect the battery: step 6, image 2 of 2
      • Use tweezers to grip the edges of the battery connector and slide it out of its socket.
      • Be careful not to scratch the circuit board with the points of your tweezers.
      Ask FixBot
    4. Logitech Zone Wireless 2 Battery Replacement, Remove the battery: step 7, image 1 of 3 Logitech Zone Wireless 2 Battery Replacement, Remove the battery: step 7, image 2 of 3 Logitech Zone Wireless 2 Battery Replacement, Remove the battery: step 7, image 3 of 3
      • Use your fingers to lift and remove the battery out of the ear cup.
      • During reassembly, it may be easier to reconnect the battery first before laying it in place.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
Author
with
Arthur Shi
354,431 Reputation
938 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 35
Past 30 Days: 185
All Time: 1,582
