Logitech Zone Vibe 100 Battery Replacement
    1. Logitech Zone Vibe 100 Battery Replacement, Earpads: step 1, image 1 of 1
      • Pry open both the right earpad and left earpad carefully with your hands.
      Ask FixBot
    1. Logitech Zone Vibe 100 Battery Replacement, Battery: step 2, image 1 of 1
      • Remove the four Phillips #00 screws that secure the right driver cover.
      Ask FixBot
    2. Logitech Zone Vibe 100 Battery Replacement: step 3, image 1 of 2 Logitech Zone Vibe 100 Battery Replacement: step 3, image 2 of 2
      • Gently lift off the right driver cover with your hands.
      • The cover is still connected by some wires going from a small daughter board to the speaker, so be careful to not tangle, strain, or rip them.
      Ask FixBot
    3. Logitech Zone Vibe 100 Battery Replacement: step 4, image 1 of 1
      Tool used on this step:
      Tesa 61395 Tape
      $2.95
      Buy
      • Grip and pull the white battery connector directly out of its socket.
      • Use an opening tool to gently pry the battery up and off of the housing.
      • Take care not to bend, twist, or puncture the battery.
      • Remove the battery.
      • During reassembly:
      • When installing a new battery, make sure the end with cables is near the bottom of the ear cup so the connector can reach its socket.
      • If your replacement battery comes with adhesive pre-installed, remove the plastic liner and press the battery into place.
      • If your replacement battery doesn't come with adhesive pre-installed, use strips of double-sided tape to secure it in the recess.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Allison T
451 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 102
All Time: 840
