Logitech Zone 305 Ear Pads Replacement
    1. Logitech Zone 305 Ear Pads Replacement, Prepare the headset for disassembly: step 1, image 1 of 1
      • Power off the headset and unplug all cables.
      Ask FixBot
    2. Logitech Zone 305 Ear Pads Replacement, Remove the ear pad: step 2, image 1 of 3 Logitech Zone 305 Ear Pads Replacement, Remove the ear pad: step 2, image 2 of 3 Logitech Zone 305 Ear Pads Replacement, Remove the ear pad: step 2, image 3 of 3
      • If you're replacing the headset battery, you only need to remove the right ear pad.
      • With one hand, firmly hold the ear cup steady.
      • With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
      • Remove the ear pad from the ear cup.
      Ask FixBot
    1. Logitech Zone 305 Ear Pads Replacement, Install the ear pad: step 3, image 1 of 3 Logitech Zone 305 Ear Pads Replacement, Install the ear pad: step 3, image 2 of 3 Logitech Zone 305 Ear Pads Replacement, Install the ear pad: step 3, image 3 of 3
      • Installing the ear pad can be tricky. Be patient and work slowly—it may take a couple tries.
      • With one hand, firmly hold an ear cup steady.
      • With your free hand, place the pad over the top of the cup, so the fabric flap slips over the cup's plastic lip.
      • Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
      • Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
      Ask FixBot
Arthur Shi
347,718 Reputation
927 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 28
All Time: 207
