Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓Follow this guide to replace a worn-out or dead battery in your Logitech Zone 300 headset. The battery resides within the right ear cup.
It’s natural for batteries to lose capacity as they age. If your headset dies quickly and doesn't hold a charge, it may be time to replace the battery.
For safety, perform this repair when your battery is below 15% charge. Any charged lithium-ion battery can be hazardous if punctured or damaged. If your battery looks puffy or swollen, take appropriate precautions.
With one hand, firmly hold the ear cup steady.
With your free hand, slowly pull the ear pad away from the cup until it slides completely off its plastic lip.
Remove the ear pad from the ear cup.
Insert the point of an opening pick into the seam between the speaker plate and ear cup.
Slide the pick along the seam to release the four speaker plate clips.
Use a Phillips screwdriver to remove the 7.1 mm‑long pancake screw securing the speaker housing.
Use a Phillips screwdriver to remove the three 5.3 mm‑long screws securing the midplate.
Slide the tip of an opening pick under the battery and pry gently to separate it from the midplate.
Tool used on this step:Tesa 61395 Tape$2.95
Cut and attach a small strip of double-sided tape onto the battery.
Remove the adhesive liner to expose the adhesive.
Use your fingers to unclip the speaker plate from the housing.
Use your fingers to move the speaker plate back over the speaker housing.
The top clip is wider than the rest of the clips and is located above a set of vent holes. Use this to help align the speaker plate to the housing.
With one hand, firmly hold an ear cup steady.
With your free hand, place the pad over the top of the cup, so the fabric flap slips over the cup's plastic lip.
Thread the rest of the flap over the lip, working your way around the entire cup. Gently stretch the pad as necessary.
Check the entire perimeter of the cup to make sure the ear pad is fully on. If any of the fabric flap is sticking out, try to push it over the lip or remove the ear pad and try again.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
