Using a TORX T10H bit, under the flip cover/stand, remove the four screws holding the battery cover in place.
The battery can be easily removed by using your fingernail or a small flathead to pry the connector free. It is held in place by tension on both sides. Once detached, flip the speaker over and the battery will fall out.
A replacement battery can be purchased from Amazon at the link below, or search for "NiMH 3.6v 1800mAh rechargeable battery" Amazon.com
Reinstall battery and cover.
3 other people completed this guide.
2 Guide Comments
My speaker is very old, and neglected, but I still had the power supply for it.
My battery cover only had two screws. The battery replacement was as described in the tutorial.
Glad I had this guide before I started removing the wrong screws!
Logitech is very good quality.
Thanks.
