Logitech Wireless K360 Printed Circuit Board (PCB) Replacement
    1. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement, Battery: step 1, image 1 of 1
      • Turn the keyboard face down.
      Ask FixBot
    2. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: step 2, image 1 of 1
      • With your thumbs on both sides of the battery tab, push upwards.
      • You should feel it disconnect.
      • Remove the cover exposing the batteries.
      Ask FixBot
    3. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: step 3, image 1 of 1
      • Remove the old batteries.
      • Make sure the keyboard turns on and works.
      • Double check that the cover is back on correctly; you don't want it coming off and have the batteries fall out!
      Ask FixBot
    1. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement, Printed Circuit Board (PCB): step 4, image 1 of 3 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement, Printed Circuit Board (PCB): step 4, image 2 of 3 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement, Printed Circuit Board (PCB): step 4, image 3 of 3
      • Remove the keyboard cover.
      • Remove the screws using a Phillips #0 screwdriver.
      • There are a total of eight 8mm screws and twelve 6mm screws.
      Ask FixBot
    2. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: step 5, image 1 of 2 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: step 5, image 2 of 2
      • Remove the top half of the keyboard carefully.
      • If there are issues removing the top half of the keyboard, you can try using something thin to get into the crevices.
      Ask FixBot
    3. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: step 6, image 1 of 3 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: step 6, image 2 of 3 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: step 6, image 3 of 3
      • Unscrew the two 2.0 mm silver screws using a Phillips #0 screwdriver.
      Ask FixBot
    4. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: step 7, image 1 of 3 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: step 7, image 2 of 3 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: step 7, image 3 of 3
      • Unscrew the two 2.0 mm silver screws on either side of the printed circuit board (PCB) using a Phillips #0 screwdriver.
      Ask FixBot
    5. Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: step 8, image 1 of 3 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: step 8, image 2 of 3 Logitech Wireless K360 Printed Circuit Board (PCB) Replacement: step 8, image 3 of 3
      • Lift the entire printed circuit board (PCB) out of the panel.
      Ask FixBot
4 other people completed this guide.
Othon Sanchez
349 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 83
All Time: 732
