Up to 20% off select tools
Logitech Webcam Pro 9000 USB Connection Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
100
All Time:
2,816
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. Logitech Webcam Pro 9000 USB Connection Replacement, Front and Back Cover: step 1, image 1 of 2 Logitech Webcam Pro 9000 USB Connection Replacement, Front and Back Cover: step 1, image 2 of 2
      • Remove the two 8 mm Phillips #0 screws on the back cover.
      • The motherboard connects the two covers together. DO NOT separate the two yet.
      • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
      Ask FixBot
    2. Logitech Webcam Pro 9000 USB Connection Replacement: step 2, image 1 of 2 Logitech Webcam Pro 9000 USB Connection Replacement: step 2, image 2 of 2
      • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
      • DO NOT detach the wire connecting the motherboard to the front cover.
      Ask FixBot
    1. Logitech Webcam Pro 9000 USB Connection Replacement, USB Connection: step 3, image 1 of 2 Logitech Webcam Pro 9000 USB Connection Replacement, USB Connection: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to grasp the white wire connector on the back of the motherboard.
      • Wiggle the connector back and forth to remove it from the socket.
      Ask FixBot
    2. Logitech Webcam Pro 9000 USB Connection Replacement: step 4, image 1 of 2 Logitech Webcam Pro 9000 USB Connection Replacement: step 4, image 2 of 2
      • Desolder the joint on the front of the motherboard to completely detach the USB cable.
      • Follow this link to learn how to properly solder and desolder your parts.
      Ask FixBot
Author
with
Cory Davis
236 Reputation
4 Guides authored
Cal Poly, Team 12-34, Amido Spring 2013 Member of Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Members
96 Guides authored
1 Guide Comment
what is the connector called
Anirudh Krishnan - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 100
All Time: 2,816
