Logitech Webcam Pro 9000 Motherboard Replacement
    1. Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: step 1, image 1 of 2 Logitech Webcam Pro 9000 Motherboard Replacement, Front and Back Cover: step 1, image 2 of 2
      • Remove the two 8 mm Phillips #0 screws on the back cover.
      • The motherboard connects the two covers together. DO NOT separate the two yet.
      • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
      Ask FixBot
    2. Logitech Webcam Pro 9000 Motherboard Replacement: step 2, image 1 of 2 Logitech Webcam Pro 9000 Motherboard Replacement: step 2, image 2 of 2
      • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
      • DO NOT detach the wire connecting the motherboard to the front cover.
      Ask FixBot
    1. Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: step 3, image 1 of 3 Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: step 3, image 2 of 3 Logitech Webcam Pro 9000 Motherboard Replacement, Snapshot button: step 3, image 3 of 3
      • Grasp the white connector attaching the button chip wire to the motherboard.
      • Grab between the tabs and the socket.
      • Wiggle the connector back and forth to remove it from the connection box
      • Do not worry if you detach the red and black wire connection on the power button.
      Ask FixBot
    1. Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: step 4, image 1 of 2 Logitech Webcam Pro 9000 Motherboard Replacement, Microphone Connection: step 4, image 2 of 2
      • Grasp the white wire connector between the tabs and the socket.
      • Wiggle the connector back and forth to remove the front cover from the motherboard.
      Ask FixBot
    1. Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: step 5, image 1 of 2 Logitech Webcam Pro 9000 Motherboard Replacement, USB Connection: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to grasp the white wire connector on the back of the motherboard.
      • Wiggle the connector back and forth to remove it from the socket.
      Ask FixBot
    2. Logitech Webcam Pro 9000 Motherboard Replacement: step 6, image 1 of 2 Logitech Webcam Pro 9000 Motherboard Replacement: step 6, image 2 of 2
      • Desolder the joint on the front of the motherboard to completely detach the USB cable.
      • Follow this link to learn how to properly solder and desolder your parts.
      Ask FixBot
    1. Logitech Webcam Pro 9000 Motherboard Replacement, Camera: step 7, image 1 of 1
      • Remove the two 8mm Phillips#0 screws on the back of the motherboard.
      Ask FixBot
    2. Logitech Webcam Pro 9000 Motherboard Replacement: step 8, image 1 of 3 Logitech Webcam Pro 9000 Motherboard Replacement: step 8, image 2 of 3 Logitech Webcam Pro 9000 Motherboard Replacement: step 8, image 3 of 3
      • Remove the camera from the motherboard by desoldering the two connections as shown.
      Ask FixBot
Cory Davis
236 Reputation
4 Guides authored
Cal Poly, Team 12-34, Amido Spring 2013 Member of Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Members
90 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 35
All Time: 2,652
