Logitech VX Revolution Teardown
Views: 2.7K
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
76
All Time:
2,691
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 45 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. Logitech VX Revolution Teardown, Preparation: step 1, image 1 of 1
      • Remove the Wireless Adapter.
      Ask FixBot
    2. Logitech VX Revolution Teardown, Remove screws: step 2, image 1 of 1
      • Remove the 5 skatepads carefully using a scalpel and tweezers or small pliers. Do not throw them away if you do not have a replacement at hand.
      • Do not throw away the skatepads, it is very difficult to find new ones.
      • Remove the 5 screws using a Phillips screwdriver (Size PH1).
      Ask FixBot
    3. Logitech VX Revolution Teardown, Opening the mouse: step 3, image 1 of 1
      • Open the device as shown in the image without force.
      • You can remove the flex cable after carefully lifting the brown plastic part using finger nail or a small srew driver.
      • To remove the mouse wheel, the marked screw has to be removed using a PH1 screwdriver.
      Ask FixBot
    4. Logitech VX Revolution Teardown, The Scroll Wheel: step 4, image 1 of 1
      • The assembly consists after the removal of the screw (left) of a plastic part laying on the PCB and the main assembly.
      • Furthermore, a small spring belongs to the assembly, which may be secured till reassembly by using a magnet.
      Ask FixBot
    5. Logitech VX Revolution Teardown, The battery housing: step 5, image 1 of 1
      • The battery case lays loosely in top of the base assembly and is connected to the main PCB using a small connector.
      Ask FixBot
    6. Logitech VX Revolution Teardown, The Transmitter Mount: step 6, image 1 of 1
      • The case for the transmitter isn't secured by any screw and can be removed by lifting it out of the mouse with very little force.
      • To remove the PCB board, unscrew the two screws using a PH00 bit.
      Ask FixBot
    7. Logitech VX Revolution Teardown, The PCB Board: step 7, image 1 of 2 Logitech VX Revolution Teardown, The PCB Board: step 7, image 2 of 2
      • Backside of the PCB. The markings illustrate the positions of the mouse buttons (type D2FC-F-7N).
      • Contacts for the right mouse button. Desolder if neccessary.
      • Contacts for the left mouse button. Desolder if neccessary.
      Ask FixBot
    8. Logitech VX Revolution Teardown, Steps for Reassembaly: step 8, image 1 of 1
      • Follow the previous steps in reverse for reassembly.
      • The mouse wheel assembly has a small metal pin in the front. This pin has to fit inside the hole in the loos plastic part.
      • It is recommended to combine the assembly and the plastic part before reinserting them to their final spot. Furthermore, the battery box shoud be assembled thereafter to simplify the process.
      • Check the functionality of the mouse before reapplying the skate pads.
      Ask FixBot
Finish Line
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Florian Kleiner
392 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 76
All Time: 2,691
