Logitech UE Megablast Speaker Replacement
    1. Logitech UE Megablast Speaker Replacement, Battery: step 1, image 1 of 3 Logitech UE Megablast Speaker Replacement, Battery: step 1, image 2 of 3 Logitech UE Megablast Speaker Replacement, Battery: step 1, image 3 of 3
      • Turn the silver D-ring on one end of the speaker counterclockwise with your fingers to remove it.
      Ask FixBot
    2. Logitech UE Megablast Speaker Replacement: step 2, image 1 of 3 Logitech UE Megablast Speaker Replacement: step 2, image 2 of 3 Logitech UE Megablast Speaker Replacement: step 2, image 3 of 3
      • Insert the blue iFixit opening tool between the rubber end and the mesh.
      • Pry the rubber end to remove it.
      Ask FixBot
    3. Logitech UE Megablast Speaker Replacement: step 3, image 1 of 3 Logitech UE Megablast Speaker Replacement: step 3, image 2 of 3 Logitech UE Megablast Speaker Replacement: step 3, image 3 of 3
      • Use a Phillips #2 screwdriver to remove the four 12 mm screws.
      Ask FixBot
    4. Logitech UE Megablast Speaker Replacement: step 4, image 1 of 3 Logitech UE Megablast Speaker Replacement: step 4, image 2 of 3 Logitech UE Megablast Speaker Replacement: step 4, image 3 of 3
      • Use the iFixit opening tool to gently pry the black plastic cover out of the end of the speaker.
      Ask FixBot
    5. Logitech UE Megablast Speaker Replacement: step 5, image 1 of 3 Logitech UE Megablast Speaker Replacement: step 5, image 2 of 3 Logitech UE Megablast Speaker Replacement: step 5, image 3 of 3
      • Gently pull the 3400 mAh rechargeable lithium-ion battery straight out of the speaker.
      Ask FixBot
    1. Logitech UE Megablast Speaker Replacement, Speaker: step 6, image 1 of 3 Logitech UE Megablast Speaker Replacement, Speaker: step 6, image 2 of 3 Logitech UE Megablast Speaker Replacement, Speaker: step 6, image 3 of 3
      • Use an iFixit opening tool to gently lift a corner of the rubber spine.
      • Start from a side that is easier to grip (usually the bottom or the side).
      • Slowly pull the rubber upward around each button, checking for any adhesive spots or clips and detaching them carefully.
      Ask FixBot
    2. Logitech UE Megablast Speaker Replacement: step 7, image 1 of 3 Logitech UE Megablast Speaker Replacement: step 7, image 2 of 3 Logitech UE Megablast Speaker Replacement: step 7, image 3 of 3
      • Use an iFixit opening tool to gently pry up the lip at the top of the spine, starting at the 9 o’clock position, to release the latch.
      • Continue to pry around the edge of the lid towards the 6 and 3 o’clock positions until it is completely removed.
      • Carefully remove the spine with the top and bottom ends attached to avoid tearing it.
      Ask FixBot
    3. Logitech UE Megablast Speaker Replacement: step 8, image 1 of 1
      • Use a pair of tweezers to pull down the flaps near the top back of the speaker.
      Ask FixBot
    4. Logitech UE Megablast Speaker Replacement: step 9, image 1 of 2 Logitech UE Megablast Speaker Replacement: step 9, image 2 of 2
      • Gently use a pair of tweezers to lift a corner of the fabric mesh from the frame.
      • Slide an opening pick along the edges to slowly free the mesh, being careful not to tear it.
      Ask FixBot
    5. Logitech UE Megablast Speaker Replacement: step 10, image 1 of 2 Logitech UE Megablast Speaker Replacement: step 10, image 2 of 2
      • Gently slide an opening pick or tweezers under the top edge of the fabric mesh to detach it from the top and bottom of the speaker.
      Ask FixBot
    6. Logitech UE Megablast Speaker Replacement: step 11, image 1 of 2 Logitech UE Megablast Speaker Replacement: step 11, image 2 of 2
      • Carefully remove the mesh and set it aside for reassembly.
      Ask FixBot
    7. Logitech UE Megablast Speaker Replacement: step 12, image 1 of 3 Logitech UE Megablast Speaker Replacement: step 12, image 2 of 3 Logitech UE Megablast Speaker Replacement: step 12, image 3 of 3
      • Use the iFixit opening tool to release the clips along the seam, starting at a corner or the side
      • Gently lift the plastic cover away from the body to expose the speaker underneath.
      Ask FixBot
    8. Logitech UE Megablast Speaker Replacement: step 13, image 1 of 3 Logitech UE Megablast Speaker Replacement: step 13, image 2 of 3 Logitech UE Megablast Speaker Replacement: step 13, image 3 of 3
      • Use the Phillips #2 screwdriver to remove the Bluetooth button board from the Megablast.
      • Lift the Bluetooth button PCB and slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the board.
      • Remove the PCB and set it aside.
      Ask FixBot
    9. Logitech UE Megablast Speaker Replacement: step 14, image 1 of 2 Logitech UE Megablast Speaker Replacement: step 14, image 2 of 2
      • Using a screwdriver, gently push out the hooked portions of the metal rods from the Megablast.
      Ask FixBot
    10. Logitech UE Megablast Speaker Replacement: step 15, image 1 of 3 Logitech UE Megablast Speaker Replacement: step 15, image 2 of 3 Logitech UE Megablast Speaker Replacement: step 15, image 3 of 3
      • Use a pair of tweezers to grip the end and gently pull each rod straight out, avoiding any bending or twisting.
      • Set the rods aside.
      Ask FixBot
    11. Logitech UE Megablast Speaker Replacement: step 16, image 1 of 3 Logitech UE Megablast Speaker Replacement: step 16, image 2 of 3 Logitech UE Megablast Speaker Replacement: step 16, image 3 of 3
      • Use the iFixit opening tool to release the clips holding the speaker in place.
      Ask FixBot
    12. Logitech UE Megablast Speaker Replacement: step 17, image 1 of 3 Logitech UE Megablast Speaker Replacement: step 17, image 2 of 3 Logitech UE Megablast Speaker Replacement: step 17, image 3 of 3
      • Before you remove the speaker, pull the white speaker connector from the motherboard.
      • Remove the speakers from the device.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 45
All Time: 313
