Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓Is the power button in your UE Megablast feel like it gets stuck, cracks when pushed, or just doesn't power on the speaker? This guide will show you how to replace the battery in your UE Megablast speaker
Check the troubleshooting pages first to confirm that your speaker needs a new Power Button Assembly.
Before you begin this repair, turn off and unplug the speaker from the charger.
Tools
Turn the silver D-ring on one end of the speaker counterclockwise with your fingers to remove it.
Use an iFixit opening tool to gently pry open the lid at the top of the spine, starting at the 9 o’clock position as shown in the picture.
Continue to carefully pry toward the 6 and 3 o’clock positions until the spine and ends are completely detached from the speaker body.
Once all the edges are free, gently remove the spine and ends to avoid tearing.
Use the iFixit opening tool to gently pry the black plastic button board cover from the end of the speaker.
Remove the Bluetooth button board from the device.
Careful as you lift the board to avoid ripping the ribbon cable and coaxial cable connectors.
Slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the coaxial connector (as close to the head as possible) and lift straight up from the board.
Remove the PCB and set it aside.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
