Introduction
Does your charging port feel a little loose? You've tested your charging cable and that wasn't the issue? This guide will help you replace the faulty charging port on your UE Megablast.
Check the troubleshooting page to confirm if your device will need a replacement charging port.
Before you begin this repair, turn off and unplug the speaker from the charger.
Turn the silver D-ring on one end of the speaker counterclockwise with your fingers to remove it.
Pull the flap out to remove the rubber ring surrounding the D-ring socket.
To begin reassembly with the final step shown, then proceed backwards to step one. Charging port will be fully functional.
