Logitech UE Megablast Battery Replacement
    1. Logitech UE Megablast Battery Replacement, Battery: step 1, image 1 of 3 Logitech UE Megablast Battery Replacement, Battery: step 1, image 2 of 3 Logitech UE Megablast Battery Replacement, Battery: step 1, image 3 of 3
      • Turn the silver D-ring on one end of the speaker counterclockwise with your fingers to remove it.
      Ask FixBot
    2. Logitech UE Megablast Battery Replacement: step 2, image 1 of 3 Logitech UE Megablast Battery Replacement: step 2, image 2 of 3 Logitech UE Megablast Battery Replacement: step 2, image 3 of 3
      • Insert the blue iFixit opening tool between the rubber end and the mesh.
      • Pry the rubber end to remove it.
      Ask FixBot
    3. Logitech UE Megablast Battery Replacement: step 3, image 1 of 3 Logitech UE Megablast Battery Replacement: step 3, image 2 of 3 Logitech UE Megablast Battery Replacement: step 3, image 3 of 3
      • Use a Phillips #2 screwdriver to remove the four 12 mm screws.
      Ask FixBot
    4. Logitech UE Megablast Battery Replacement: step 4, image 1 of 3 Logitech UE Megablast Battery Replacement: step 4, image 2 of 3 Logitech UE Megablast Battery Replacement: step 4, image 3 of 3
      • Use the iFixit opening tool to gently pry the black plastic cover out of the end of the speaker.
      Ask FixBot
    5. Logitech UE Megablast Battery Replacement: step 5, image 1 of 3 Logitech UE Megablast Battery Replacement: step 5, image 2 of 3 Logitech UE Megablast Battery Replacement: step 5, image 3 of 3
      • Gently pull the 3400 mAh rechargeable lithium-ion battery straight out of the speaker.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 112
All Time: 748
