Up to 20% off select tools
Logitech UE MegaBoom Outer Mesh Replacement
Views: 5.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
106
All Time:
5,399
Comments: 13
11 comments on steps, 2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This is a guide designed to assist you in removing and replacing the Logitech UE Megaboom outer mesh.
    1. Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: step 1, image 1 of 3 Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: step 1, image 2 of 3 Logitech UE MegaBoom Outer Mesh Replacement, Outer Mesh: step 1, image 3 of 3
      • Locate the ends of the speaker.
      • Put a plastic opening tool in-between the rubber end and the mesh.
      • Apply a upward force in order to pry open the end.
      • Apply this procedure to the other side as well.
      • Will take force.
      • Using metal tools may permanently mar your device.
      Ask FixBot
    2. Logitech UE MegaBoom Outer Mesh Replacement: step 2, image 1 of 3 Logitech UE MegaBoom Outer Mesh Replacement: step 2, image 2 of 3 Logitech UE MegaBoom Outer Mesh Replacement: step 2, image 3 of 3
      • Take the Jimmy and pry up the rubber strip that has the volume buttons on it.
      • You will hear clicks as it pries up, don't worry.
      • Remove all the rubber you pried off.
      Ask FixBot
    3. Logitech UE MegaBoom Outer Mesh Replacement: step 3, image 1 of 2 Logitech UE MegaBoom Outer Mesh Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to lift end of plastic retainer on edge of mesh out of its channel.
      • Work the plastic retainer out of the channel all the way around the speaker.
      • Be gentle, it is easy to damage the fabric.
      • Repeat for other side.
      Ask FixBot
Author
with
Oscar Ambriz
987 Reputation
6 Guides authored
Cal Poly, Team S9-G2, Banghart Fall 2017 Member of Cal Poly, Team S9-G2, Banghart Fall 2017
CPSU-BANGHART-F17S9G2
4 Members
84 Guides authored
2 Guide Comments
You know where to buy a replacement mesh in custom colors
Jonathan Lang - Reply Share
Bonjour merci pour le tuto mais ou trouve t-on le “outer mesh” de remplacemet????
Merci d’avance
Evan
Evan Castione - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 106
All Time: 5,399
