Tools
PliersOptional
Introduction
Go to step 1 ↓Use this guide to replace the power button board in a Logitech UE Hyperboom Bluetooth Speaker. The power button is responsible for turning on and off the speaker. The power button can be susceptible to deterioration with repeated use. If your speaker charges visibly, but you get no response from both pressing and holding the power button, this could be a sign of a power button issue.
Before beginning this guide, be sure to power off your speaker.
Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
Use the Phillips #0 screwdriver to unscrew the seven 6.5mm screws on the circuit board.
Use a metal spudger to disconnect the power button board from the panel.
