Logitech UE Hyperboom Motherboard Replacement
    1. Logitech UE Hyperboom Motherboard Replacement, Handle: step 1, image 1 of 2 Logitech UE Hyperboom Motherboard Replacement, Handle: step 1, image 2 of 2
      • Unscrew the two black flat-top screws that attach the handle to the speaker with your hands.
      • You may need pliers to grip the screws.
      Ask FixBot
    1. Logitech UE Hyperboom Motherboard Replacement, Top Panel: step 2, image 1 of 2 Logitech UE Hyperboom Motherboard Replacement, Top Panel: step 2, image 2 of 2
      • Use your hands to carefully pry the plastic cover off of the speaker.
      Ask FixBot
    2. Logitech UE Hyperboom Motherboard Replacement: step 3, image 1 of 3 Logitech UE Hyperboom Motherboard Replacement: step 3, image 2 of 3 Logitech UE Hyperboom Motherboard Replacement: step 3, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the ten 11.7mm screws on the top panel.
      • Remove the top panel to access the internal components.
      • Use a metal spudger to completely disconnect the top panel.
      Ask FixBot
    1. Logitech UE Hyperboom Motherboard Replacement, Speaker Drivers and Tweeters: step 4, image 1 of 2 Logitech UE Hyperboom Motherboard Replacement, Speaker Drivers and Tweeters: step 4, image 2 of 2
      • Use the Jimmy to pry the fiber mesh cover away from the speaker.
      • Take the fiber mesh off of the speaker completely.
      Ask FixBot
    2. Logitech UE Hyperboom Motherboard Replacement: step 5, image 1 of 3 Logitech UE Hyperboom Motherboard Replacement: step 5, image 2 of 3 Logitech UE Hyperboom Motherboard Replacement: step 5, image 3 of 3
      • Use the Phillips #0 screwdriver to unscrew the three 9.2mm screws around the tweeter speaker.
      • Use the Phillips #0 screwdriver to unscrew the eight 10.1mm screws around the speaker driver.
      • Use a metal spudger to pry the tweeter speaker out of the socket.
      Ask FixBot
    3. Logitech UE Hyperboom Motherboard Replacement: step 6, image 1 of 3 Logitech UE Hyperboom Motherboard Replacement: step 6, image 2 of 3 Logitech UE Hyperboom Motherboard Replacement: step 6, image 3 of 3
      • Use a metal spudger to break the adhesive seal around the speaker driver.
      • Use your hands to push the speaker driver out of its socket.
      • A lot of force will be necessary, so it is possible the power and ground cables might disconnect from the force of dislodging the speaker driver.
      • Disconnect the power and ground cables from both the speaker driver and tweeter.
      Ask FixBot
    4. Logitech UE Hyperboom Motherboard Replacement: step 7, image 1 of 1
      • Turn the speaker over, and face the two other speaker driver towards you.
      • Use the Phillips #0 screwdriver to remove the three 9.2mm screws around the speaker tweeter.
      • Use the Phillips #0 screwdriver to remove the eight 10.1mm screws around the speaker driver.
      Ask FixBot
    5. Logitech UE Hyperboom Motherboard Replacement: step 8, image 1 of 2 Logitech UE Hyperboom Motherboard Replacement: step 8, image 2 of 2
      • Use a metal spudger to break the adhesive between the tweeter and the casing.
      • Disconnect the power and ground cables from the tweeter speaker to remove it completely.
      Ask FixBot
    6. Logitech UE Hyperboom Motherboard Replacement: step 9, image 1 of 3 Logitech UE Hyperboom Motherboard Replacement: step 9, image 2 of 3 Logitech UE Hyperboom Motherboard Replacement: step 9, image 3 of 3
      • Use your hands to remove the speaker driver from its socket.
      • Disconnect the power and ground cables to remove it completely.
      Ask FixBot
    1. Logitech UE Hyperboom Motherboard Replacement, Motherboard: step 10, image 1 of 2 Logitech UE Hyperboom Motherboard Replacement, Motherboard: step 10, image 2 of 2
      • Disconnect all of the cables connected to the motherboard.
      Ask FixBot
    2. Logitech UE Hyperboom Motherboard Replacement: step 11, image 1 of 3 Logitech UE Hyperboom Motherboard Replacement: step 11, image 2 of 3 Logitech UE Hyperboom Motherboard Replacement: step 11, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the four supporting 7.9mm screws.
      • Slide the motherboard out of the top of the speaker.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 93
All Time: 246
