Up to 20% off select tools
Logitech UE Boom USB Port Replacement
Views: 40K
View statistics:
Past 24 Hours:
9
Past 7 Days:
43
Past 30 Days:
184
All Time:
39,533
Comments: 34
19 comments on steps, 15 guide comments.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Logitech UE Boom USB Port Replacement, D-ring: step 1, image 1 of 1
      • Turn the device over. The D-ring will be on the left face of the speaker when viewing the device from this orientation.
      Ask FixBot
    2. Logitech UE Boom USB Port Replacement: step 2, image 1 of 2 Logitech UE Boom USB Port Replacement: step 2, image 2 of 2
      • Lift the handle on the D-ring and unscrew it.
      • Remove the D-ring.
      Ask FixBot
    1. Logitech UE Boom USB Port Replacement, Bluetooth Adapter: step 3, image 1 of 1
      • Any repairs made from this point forward will void your device's warranty.
      • Holding the speaker upright, wedge the metal spudger in between the casing and the speaker. Gently pry open the tabs as they are easily broken.
      Ask FixBot
    2. Logitech UE Boom USB Port Replacement: step 4, image 1 of 3 Logitech UE Boom USB Port Replacement: step 4, image 2 of 3 Logitech UE Boom USB Port Replacement: step 4, image 3 of 3
      • Find the part of the casing that covers the volume controls. Wedge the metal spudger under this and pry open all of the tabs as in the previous step.
      • Repeat for the bottom of the speaker and pry the casing open with your fingers.
      Ask FixBot
    3. Logitech UE Boom USB Port Replacement: step 5, image 1 of 2 Logitech UE Boom USB Port Replacement: step 5, image 2 of 2
      • Using the Phillips J0 head screwdriver, unscrew the four silver 9 mm screws.
      • Do the same for the two black 7 mm screws.
      Ask FixBot
    4. Logitech UE Boom USB Port Replacement: step 6, image 1 of 3 Logitech UE Boom USB Port Replacement: step 6, image 2 of 3 Logitech UE Boom USB Port Replacement: step 6, image 3 of 3
      • This next step involves the use of a hot soldering iron. Remember to be careful during this step since it can be easy to burn yourself.
      • Using a soldering iron, de-solder the two ends of the switch plate. Desolder the two terminals on headphone jack side first, as the middle connection is notched and should be slid out when molten.
      Ask FixBot
    5. Logitech UE Boom USB Port Replacement: step 7, image 1 of 1
      • With the switch plate disconnected, remove it and your device should now look like this.
      Ask FixBot
    1. Logitech UE Boom USB Port Replacement, Lithium Battery: step 8, image 1 of 1
      • With a metal spudger, pry open the tabs on the speaker sleeve along the length of the speaker.
      Ask FixBot
    2. Logitech UE Boom USB Port Replacement: step 9, image 1 of 1
      • Use a plastic opening tool to pry the sleeve off from the bottom of the speaker.
      Ask FixBot
    3. Logitech UE Boom USB Port Replacement: step 10, image 1 of 3 Logitech UE Boom USB Port Replacement: step 10, image 2 of 3 Logitech UE Boom USB Port Replacement: step 10, image 3 of 3
      • Peel off the sleeve.
      Ask FixBot
    4. Logitech UE Boom USB Port Replacement: step 11, image 1 of 2 Logitech UE Boom USB Port Replacement: step 11, image 2 of 2
      • Use a Phillips 1 screwdriver to unscrew the eight black 14 mm screws along the length of the casing.
      Ask FixBot
    5. Logitech UE Boom USB Port Replacement: step 12, image 1 of 2 Logitech UE Boom USB Port Replacement: step 12, image 2 of 2
      • With the screws removed, pry open the casing to be able to get to the components inside.
      • Try prying the case open from one of the ends if that is easier.
      Ask FixBot
    6. Logitech UE Boom USB Port Replacement: step 13, image 1 of 2 Logitech UE Boom USB Port Replacement: step 13, image 2 of 2
      • With a Phillips #00 screwdriver, unscrew two 5.6 mm screws from the rectangular shaped circuit board.
      Ask FixBot
    7. Logitech UE Boom USB Port Replacement: step 14, image 1 of 1
      • With the Phillips #2 screwdriver, unscrew the 9.9 mm screw from the larger circuit board surrounding the speaker.
      Ask FixBot
    8. Logitech UE Boom USB Port Replacement: step 15, image 1 of 1
      • Once all of the screws are gone, you should be able to remove the circuit boards and find the battery.
      Ask FixBot
    9. Logitech UE Boom USB Port Replacement: step 16, image 1 of 2 Logitech UE Boom USB Port Replacement: step 16, image 2 of 2
      • Remove the battery by pulling it from the terminal as marked in the picture.
      Ask FixBot
    1. Logitech UE Boom USB Port Replacement, USB Port: step 17, image 1 of 2 Logitech UE Boom USB Port Replacement, USB Port: step 17, image 2 of 2
      • Finally, after opening the speaker, locate the USB plate on the left face of the speaker and remove it from the motherboard.
      Ask FixBot
9 other people completed this guide.
Author
with
Sean Reilly
1,808 Reputation
2 Guides authored
Cal Poly, Team 4-1, Maness Fall 2015 Member of Cal Poly, Team 4-1, Maness Fall 2015
CPSU-MANESS-F15S4G1
4 Members
72 Guides authored
15 Guide Comments
Hello,
does anyone know where to get new usb port, the logitech support didn“t really help.
cheers marius
kok0dora94 - Reply Share
Same question as above, where can i buy a replacement USB port?
Corbett Hix - Reply Share
i found 10 of them on ebay for 3-4 dollars
johnsonjohnsonalexalex - Reply Share
Hi there , can you give me a link to Ebay where to find this port, thanks
katiecrow - Reply Share
can you send me a link on ebay where to find this replacement port , thanks
Past 24 Hours: 9
Past 7 Days: 43
Past 30 Days: 184
All Time: 39,533
